LED Reverse Lights | FerrariChat
LED Reverse Lights
Discussion in '348/355' started by 8500rpm, Dec 30, 2015.
  1. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    546
    San Francisco Bay
    Chan
    #1 8500rpm, Dec 30, 2015
    One of my reverse bulbs has burnt out, so I decided to replace both to keep the outer lens cool.
    FYI, I used the 1156 45-LED tower from superbrightleds.com
    The colour match is surprisingly good with the "warm white" option. Brightness is slightly stronger than the original filament bulb, but I'm glad to put a stop to the reverse lens cracking and warping. The radiation pattern is reasonably uniform and it looks 90% original when illuminated.
    Left side is the original bulb; right side is the new LED assembly.
  2. jford10014
    jford10014 F1 Rookie
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Hi. Looks great. This afternoon I catalogued all the bulbs for my 348. On the superbright website it suggests using 26 or 18 smd for the 348. I looked up the 355 on the site but they haven't databases that model yet.
    Why did you go for the 45? Did it fit ok?
    Jason
  3. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    The original bulbs are fairly large, and the 45-LED tower is just a little smaller than the glass bulb. So fitment isn't an issue.
    I chose this one because it has a near-OEM brightness (a little stronger) and a relatively uniform radiation pattern. The "warm white" colour may not be available for all models, so that was also a factor in my choice. The radiated colour is very close to the old filament bulb.
    As long as it has the correct socket (mine is 1156), it should fit.
    See here for comparison:
  4. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    thats nice :)
  5. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    #5 8500rpm, Jan 2, 2016
  6. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    1,154
    Sarasota, Florida
    OC
    I think it's funny ppl still white out the license plates in pics. Long gone are the days of the "DMV" bandits.
    BTW great mod. Love LED's
  7. jford10014
    Feb 28, 2004
    2,738
    New York, NY
    Jason
    Looks great. I'm going to prder some for my 348
  8. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    It's a cultural thing. Where I'm from (Hong Kong) it's rude to post an acquaintance's car with the plate. For random sightings it's OK.
  9. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Good call. I did this a while back after spending $300 to replace two cracked real tail lights from the heat. This should be a "must do" for anyone wanting to protect the lights from cracking. Unless, of course, you never use your brakes :)
  10. f355spider
    f355spider F1 World Champ
    18,053
    The brake lights aren't really causing the melting, the back up lights are. If you remove the bulb holder, you can see how the back up bulb is physically positioned much closer to the lens than the brake lights...that is the reason for the melting. Bad design...and these tail lights first came out in the 512M in 1994...they used them in the 355, 550, 575 and 360...never improving or modifying them during the 11 years they were installed in new production cars...just letting them eventually all melt.
  11. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Another design wonder from Ferrari!
  12. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    My bad calling them the brake lights in my post. Its the reverse lights that crack the lenses and are the ones that I replaced as noted elsewhere in this thread.
  13. tres55
    tres55 F1 Rookie
    3,572
    Canada
    It costs a lot of money to have a tail light DOT approved and Ferrari wasn't exactly in the best financial position at that time.
  14. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,991
    Northeast U.S.
    Jim
    Looks good Chan.
  15. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Just FYI, price for the bulbs went down from $20 to $15 from Superbrightleds.com
    Well worth it to save you from replacing the tail light lens.
  16. ssnowball
    ssnowball Formula Junior
    296
    Scot
    Just ordered a set, thank you.
  17. cuneo
    cuneo Formula 3
    2,480
    One more order here, thanks Chan!!
