LED steering wheel conversion | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by 10FerrariCATX, Aug 2, 2015.
  1. 10FerrariCATX
    10FerrariCATX Karting
    Jul 24, 2015
    80
    My '10 Cali does not have the LED steering wheel. If I was to buy an LED wheel and install it on my Cali would it work or is there wiring that is not there when you don't have the LED wheel on your initial order? I know on my Porsche Panamera when you order your car w/o things like this the wiring is still in place but you just don't have the part. Therefore, if you install the part you can plug it in just like it would have come from the factory.
    Any help would be greatly appreciated as I would hate to waste $4,500!
  2. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    It doesn't matter what people on Fchat tell you because we can't be held responsible if your project goes wrong.
    You should only get advice and buy this sort of item from the same people who will install it and warranty that it will work on your car. And get the quotation properly described in writing.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    +1. Also, I think the dealer will need to re-flash the firmware so it can be recognized, even if mechanically the rest of the hardware is already there.
  4. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    It's a BIG issue with 430/Scuds and not allways work; depending on year and sw .... beware !
  5. 10FerrariCATX
    Jul 24, 2015
    80
    Thanks for info guys! I'm going to hold off until I can buy a good condition used steering wheel at a good price so if it doesn't work I'm not out as much $.
  6. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,892
    I think you should ask your dealer if it can be done. Start the conversation. He will give you a quote for parts and labor. And then with a little haggling might give you a better price.
    Of course you already know to be careful working with modern steering wheels equipped with air bags. If that air bag goes off in your face, you could be injured terribly. Broken nose, damaged eye, cuts and maybe even chipped or lost teeth.
    My Cali didn't have the LEDs but I enjoyed every 75,000 miles of her.
