LED Turn Signal Bulbs Resistor | FerrariChat
Discussion in 'Technical Q&A' started by English Rebel, Feb 5, 2014.
  1. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I converted my 360 tail and brake lights to LED and have received the ones for the turn signals. I know I need to add a resistor across the + and - leads to each bulb to stop the lights from flashing too quickly but I cannot find any information on FChat as to what size to use.
    Can someone who has done this please help
    Alan
  2. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
    What is the wattage of the bulb you are taking out. Give me that and I will do the math. I could go pull my bulb I guess but can't get to it until the afternoon.
  3. Cribbj
    Cribbj Formula 3
  4. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
  5. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
    Haven't read the thread but it should work. The differences aren't enough to cause a problem. The good news here is that you have a lot of margin in the system.
  6. The Kook Abides
    The Kook Abides F1 Rookie
    Jan 4, 2011
    3,459
    Just replace the flasher relay with an electronic one that auto compensates. They are available at all of the auto parts stores
  7. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,743
    Oregon
    Gabe V.
    ^^^^^^ THIS!
    A "no load flasher relay" eliminates butchering your wire harness with bulky unnecessary resistors.
  8. Fear.Engineer
    Fear.Engineer Rookie
    Oct 27, 2013
    17
    Poland
    Use 5,6 Ohm resistor. Honestly any 3-8 Ohm resistor will work. Remember to use high power resistors aprox 10 W.
    Best regards Kuba
    Wysłane z mojego GT-I8260 przy użyciu Tapatalka
  9. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Thanks guys I think I'll try the flasher relay as that will save time trying to figure out which wire in the harness is the one I need. Anyone know if the pins are the same as the socket?
    Alan
  10. rss04
    rss04 Karting
    Apr 14, 2008
    54
    St. Paul, Minnesota
    Alan:
    It's the blue wire. Use the 6ohm 50w resistor. Actually, join two together in series. One wire of the resistor attaches to the black wire, the other free end goes to the blue. You should be good to go.
    I got the resistors from Superbrightleds.com
    I'll post pictures of my conversion soon. Still have to get all four lights to come on with headlamps otherwise everything else is working great.
    I used theses lights.
    2X 1999 2005 Ferrari 360 LED Tail Light Taillights Retrofit Modification 42 SMD | eBay
    Love the look.
    RSS04
  11. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #12 English Rebel, Feb 7, 2014
    I think I'll see if changing the relay is a viable option first as that is the easy route. Someone suggested I get one of these but I'm still not sure on the pins. The first is for a motorcycle and the second for a car and the pin connections seem to be marked differently (it seems as if the two outside pins are reversed). Any comments will be appreciated.
    Alan
  12. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    You could always talk to Stef at Scud Ing Swiss | Home Page | ScudIng.com. He may be willing to sell the flasher he created. It is what I have in my car, and is proven to work with the LEDs in the rear and OEM filament bulbs everywhere else.
  13. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #14 English Rebel, Feb 25, 2014
    I did so and he offers a relay that is 7 pin so the 3 pin relays will not work. It's quite pricey but less than an OEM unit. I got some of these so I should be good to go and if I ever needed to remove them the wiring will still be intact as the 3M connectors do not cut through the wires.
    Alan
