Here you go for sharing. A short 3 minute video of all my LED upgrades that I posted photos and DIY info here. I upgraded all my lights to LED so I am all done. Well, almost all.... Next are front and rear side marker lights. A little more difficult to remove..... I just now noticed that the front and rear side markers will need to be upgraded to LED's too ASAP as I can see the plastic housing inside the lens is bubbling most likely due to the heat emitted by the stock incandescent bulb. Those are next. https://vimeo.com/96552255 Dan
Dan The front and rear side marker lights are easy to get at -- fronts are behind the cover where you access the headlights and the rears are below the outermost rear light cluster (F1 side is a little more difficult). I know there is not a whole lot of room between the bulb and the lens as I tried to install the same ones we use for the front marker lights and it is a tad too long. If you find a shorter one then please share. As soon as my car is back from the dealer I will be installing Stefs front and rear turn signal LEDs along with his flasher relay (all came in his new kit). Alan
Dan, Great to follow all your LED upgrades any chance you can summarize all the bulbs you orders in one post. Maybe links to eBay? how many bulbs of each? I want to order them all in one shot and do the upgrades. I own at 2003 Ferrari 360 F1 Spider as well. Thanks Roberto
Hi Roberto, Sure thing. I will work on that this weekend and will post it here once I have all the links established. Have a great weekend. Dan
Sorry still very busy with work snd family stuff. I will post LED bulb types and links to order soon including where to connect wiring for the LED welcome lights / footwell lights.
