LED's in 355 tail lights | FerrariChat
Discussion in '348/355' started by mpodgor, Sep 13, 2011.
  1. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    Has anyone tried with success in using led's in their tail lights? I replace the 8 bulbs not including the 2 backup bulbs. It was a miserable mistake. I paid for what was supposed to be bright lights. Instead, once inside the lens assembly they were very dim and the turn signal flashes quickly thinking a bulb is burnt out. So I put the regular bulbs back in. Needs a load resistor I am told. Probably a dumb idea.
  2. Rorie
    Rorie Formula Junior
    Oct 2, 2007
    459
    Toronto, Canada
    We are working on some LED's that will be bright enough for the taillights, and also be able to use for signalling (so you don't get the blub out error and the fast signalling). The idea is to sell the via Ricambi if Daniel will let us.
    Just finishing some testing at the moment.
    But if you buy the conventional LED bulb sold at farm supply stores, they are way too dim to be any good.
  3. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    If you come up with a decent lamp maybe a short You-tube clip to demonstrate. Like one side with regular bulbs and the other with the LED's to compare. It seems like companies could integrate the load resistors. Good luck. Seems like a good upgrade if it works.
  4. Rorie
    Oct 2, 2007
    459
    Toronto, Canada
    #4 Rorie, Dec 6, 2011
    I tried a prototype today of what cars now use. A computer controlled led which takes into account the load resistor. I will take some comparative pics once I get a few more bulbs. But looks very promising.
  5. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    I have LED bulbs for my reverse lights and they are perfect and don't get the lense hot in my 355.
  6. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ........ I use side indicator bulbs in the reverse postion as they are dimmer and lower heat, but the LEDs sound like they would be even cooler!!! do the LEDs light up enough to see when in reverse?
  7. ml321
    ml321 Formula Junior
    Aug 26, 2008
    254
    London/Munich
    I honestly do not understamd why people wpould do something like this. i could understa d hid fronts to see more, but why change a period car to something that it is not. Same goes for putting non period rims on them. Just buy a modern car then imo, have never seen anybody ask about something like this for an f40 or f50. just my opinion, but leave the cars as they are if the changes do not improve performance or safety
  8. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    A non load-dependent blinker module would be much better than load resistors.
    http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Ftail-brake-turn.html
    1156-x45-T: 45HP-LED BA15S Tower Bulb
    10~30VDC replacement bulb 15mm 1156 Single Intensity Bayonet Base Tower type with 45 High Power SMD LEDs
    360 degree Viewing Angle
    THIS IS OUR BRIGHTEST 1156 BULB
    Price for each.
    Select Options Part#:
    Color:
    $ 24.95
    Qty:
    1157-x45-T: 45HP-LED BAY15D Tower Bulb
    12VDC replacement bulb 15mm 1157 Dual Intensity Bayonet Base Tower type with 45 High Power SMD LEDs
    Select LED color to match vehicle lens color
    THIS IS OUR BRIGHTEST BA15 BULB
    Price for each.
    Color:
    $ 24.95
    Qty:
  9. Rorie
    Oct 2, 2007
    459
    Toronto, Canada
    LED's do improve safety as they come on quicker.
    LED's also take less load on the car wiring. They do not generate heat like regular bulbs. Especially good on older cars where heat and electrica draw can be an issue.
    Older cars were never meant to have Xenons, which take a lot of power. Way more than the original headlights. They can run into issues because of it. By changing over to low voltage LEDs you lower the overall draw on the car, making the car easier to handle the load of the xenons.
    But I agree with the comment about the rims. I am a fan of keeping things period on my vintage cars. But safety comes first.
  10. BLAMPEE
    Do you own a Ferrari that has the same lense configuration as my 355?
    The design is inferior and places the reverse bulbs like 1/100th of an inch away from the housing--the lenses melt outward and are distorted with a large bubble. Do a search; there are quite a few photos on here.
    The LED bulbs are physically smaller and give off a fraction of the heat of regular bulbs.
    Again...have you experienced this...?
  11. BLAMPEE
    #11 BLAMPEE, Dec 9, 2011
  12. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    It's hard to tell from a photo. How do the led's compare to reqular bulbs for brightness?Also, the last time I tried the car sensed they were burned out due to their internal resistance. It'll take alot to sell me.
  13. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    So can you share with us any information regarding exactly which LEDs you bought and where you got them? That would be much appreciated...
