LEDs on steering wheel do not light up at any RPM | FerrariChat
Discussion in '458 Italia/488/F8' started by sc170, Jul 14, 2015.
  1. sc170
    sc170 Karting
    Oct 5, 2012
    109
    California
    Buddy of mine picked up a 13' Spider with Carbon fiber steering wheel + LED option. His LEDs do not light up at any RPMs. We went through all the options on the left TFT, everything is set properly. What are we missing??
    Sultan_458 likes this.
  2. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    There is an option in the "setup" series of screens. . .left side of steering wheel. Turn them on.
    Melvok likes this.
  3. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    Specifcally:
    1) Select setup from main menu
    2) Select car setup from next set of menu items
    3) Select RPM on steer - turn on
    Melvok likes this.
  4. Jasone
    Jasone Formula 3
    Nov 15, 2011
    1,203
    Tampa Florida
    Jasone
    What is(was) missing is a proper PPI
    Melvok and boobernackle like this.
  5. sc170
    sc170 Karting
    Oct 5, 2012
    109
    California
    Tried it multiple times... No luck!
    Car was purchased from a reputable Ferrari Dealer... Guess that didn't matter. Car is still under factory warranty. We will just send it in for service. Thanks!
  6. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    Sorry for the issue. Hopefully it is a quick fix for the dealer. Best of luck with it.
  7. Jasone
    Jasone Formula 3
    Nov 15, 2011
    1,203
    Tampa Florida
    Jasone
    Sorry to hear that.. hope its a quick fix.
  8. RipVega
    RipVega Karting
    Jan 12, 2014
    191
    Berkshire
    I too had this problem after it had been to the dealer for non-working indicators.
    It required a part from Italy and for Ferrari to, and I quote, "Dial into the car to fix it".
    Good luck with it.
  9. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    Ah complicated divas!
    I often joke that I have four children: two human and two mechanical LOL
    Sure it will be an easy fix by dealer, and under warranty so no worries :)
    Melvok likes this.
  10. Sultan_458
    Sultan_458 Karting
    59
    Uae
    Sultan
    Hi
    Have you know what was the problem and how they fix it...
    If yes please let me know because I am having the same issue.
    Sent from my SM-N9500 using FerrariChat.com mobile app
    Melvok likes this.
  11. Gonzales25
    Gonzales25 Rookie
    Jun 4, 2018
    33
    Roberto
    Also curious mine don't light up either...
  12. SVCalifornia
    SVCalifornia F1 Rookie
    2,551
    Silicon Valley
    Keith
    Does it need to be in gear??
    SV
  13. Viperjoe
    Viperjoe F1 Rookie
    I’d try a cold reboot. Disconnect the negative battery cable for two minutes, then reconnect. It’s also possible that the software has been corrupted and will need to be reloaded by a dealer.
    338Lapua likes this.
  14. boobernackle
    boobernackle Formula Junior
    May 28, 2016
    962
    Did you make sure the vehicle was on?
    Sorry just couldn't resist... Warranty issue for sure.
  15. F485
    F485 Karting
    Oct 23, 2017
    173
    Abu Dhabi, UAE
    Fahad F458
    u can do it through the display option
  16. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    829
    Michigan
    Tony
    As Viperjoe said, the first thing to do is try a hard reboot. If that does not work, then more than likely the PC board in the steering wheel needs to be replaced. This board controls the functions on the steering wheel. If I remember correctly, the part will need to come from Italy (called the NVO board?). Additionally, there is not a separate PCB for steering wheels with or without LED's - it's the same board. The difference is, the mechanic will need to get a proxy file from Ferrari to activate the LED's. Hope this helps.
    ewright and Melvok like this.
  17. Viperjoe
    Viperjoe F1 Rookie
    I should have added that in my case, the proxy file needed to be reloaded at which point the LEDs operated normally.
  18. SVCalifornia
    2,551
    Silicon Valley
    Keith
    If a bunch of folks are noticing this then most likely Ferrari screwed up in one of its updates. It is a software problem and they have to issue an update.
    I don’t suggest taking anything apart until checking with the dealer...
    SV
    Melvok likes this.
  19. Gonzales25
    Gonzales25 Rookie
    Jun 4, 2018
    33
    Roberto
    #19 Gonzales25, Aug 2, 2018
    I just found out that my steering wheel was added after purchase, so I would assume it needs to have the proxy file up loaded... I just had it in for service and they did a software update but still no lights, going to call about the proxy file and see what's the cost to have it installed.
    Update: Just called apparently there is more involved than just hooking it up to computer?? They are checking and working up a quote. Anyone have any idea how much something like this should cost?
    Melvok likes this.
  20. 338Lapua
    Sep 5, 2015
    829
    Michigan
    Tony
    If I remember correctly, to have a new board installed cost about $1500 total (~$1000 for the NVO board and then labor). The dealer will need to get the proxy file from FNA. Since your steering wheel was added after, I'm curious what they will charge you. If they say that you require a new NVO board, I would go elsewhere.
  21. Gonzales25
    Gonzales25 Rookie
    Jun 4, 2018
    33
    Roberto
    Figured I'd give a little back story and an update:
    I bought my car used (few weeks ago) and I was told by the previous owner "that he was told when he bought the car that steering wheel was added after purchase and he didn't want to spend the $$ to get the lights working".
    BUT I was told by my local dealer/service advisor that steering wheel was on the build sheet and he didn't know why the lights didn't work and it would require sometime to diagnose the problem?? I suggested uploading the "proxy file" as read in this thread and now my lights work!!
    Now if I could actually drive fast enough to have them light up without getting arrested LOL....
  22. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,246
    Mel
    Thanx 4 valuable info: -> your leds work now !
    Do not change the gears under 7000 rpms :)
  23. boobernackle
    May 28, 2016
    962
    Rev the car in Neutral... Neighbors will love it.
    Gonzales25 likes this.
  24. Gonzales25
    Gonzales25 Rookie
    Jun 4, 2018
    33
    Roberto
    I'm sure they will especially since it has full fab speed exhaust... LMAO..
    boobernackle and Cigarzman like this.
  25. 338Lapua
    Sep 5, 2015
    829
    Michigan
    Tony
    That's great the dealer was able to get the proxy file. Glad it worked out for you and it didn't seem like it cost anything expect some time.
