left radiator fan not working . | FerrariChat
Discussion in 'Mondial' started by AUDIO RESEARCH, Nov 19, 2024.
  1. AUDIO RESEARCH
    AUDIO RESEARCH Formula Junior
    Feb 11, 2009
    392
    PHILIPPINES
    LUIGI RAYMUND LIRA
    A month ago a notice the operating temp of my Mondial was slightly higher than 1/2 according to the temp gauge when stuck in traffic . Turns out one of the radiator fan is not working . Called my tech and he discovered that one of the fuse connectors melted . He told me to order this fuse connectors so he can fix it properly . Good thing RedBay ( Stefan ) sells them . Ordered them upon arrival I called my tech . Installation was straight forward except for difficulty in locking them in place . My tech using a small Dremmel tool trimmed some parts of the locking parts of the new connector and then they locked in place . Road tested the Mondial , got stuck in traffic the temp stayed just before the half indicator of the temp gauge w/ the AC on and w/ the hot humid weather .
    MaranelloMark likes this.
  2. Alden
    Alden F1 Rookie
    3,581
    Central Florida
    The problem is not the white connector, it's the female connectors that fit into it, their contact area is not wide enough. It's only about 1/8 of an inch, and they don't have enough spring tension, clamping pressure, to hold tightly. When mine showed these symptoms I replaced them with 3/16" gold-plated females. If you don't do something about the connections underneath, this will happen again, it happens on the fuel pump and condenser fan circuits as well. I also have a GT parts replacement circuit board, which helps, but the connectors are simply too small for the load they carry, especially if they get a little dirty. Little dirty. Also spray everything with deoxit!
    Alden
  3. Alden
    Alden F1 Rookie
    3,581
    Central Florida
  4. AUDIO RESEARCH
    Feb 11, 2009
    392
    PHILIPPINES
    LUIGI RAYMUND LIRA
    Thank you very much Alden for the tip , I will ask my tech to replace those connectors .Btw Alden what is the Bosch part no. of the radiator fan relays ,is it also 0332019151?
  5. Alden
    Alden F1 Rookie
    3,581
    Central Florida
    Yes, the relays are color coded on the drawing that way. Thanks to user Afterburner for the excellent color electrical drawings!
    Alden
    AUDIO RESEARCH likes this.
  6. AUDIO RESEARCH
    Feb 11, 2009
    392
    PHILIPPINES
    LUIGI RAYMUND LIRA
    Thank you Alden
    Alden likes this.
