Lefty-loosey-righty-tighty??? | FerrariChat
Discussion in 'Technical Q&A' started by troy_wood, Nov 7, 2008.
  1. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    I don't mean to steal your sayings Ernie. In the middle of my 30k major. A few questions fellas:
    1. Is there any nut/bolt on my 348 with reverse threading?
    2. Are there any nut/bolts that are 'torque once only' and therefore should be replaced?
    3. Are there any nut/bolts in your opinion that SHOULD be 'torque once only'?
    Thanks you guys - I must say, as a novice the tightening and loosening nuts/bolts is quite concearning to me. Eventhough I have torque specs its not quite as simple as lefty-loosey-righty-tighty.
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    1. No
    2. Only some internal to engine/trans.
    3. i replace almost all hardware during a major fwiw. And yes, use a torque wrench, too often majority of opinion seems to be "if tight is good, tighter must be better!".
    Just spent 4 hours drilling out a broken stud at the front of a 355 because someone decided it needed sealant and to be super tight. A quick gasket replacement became a full days work. Thanks whoever you were!
  3. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Thanks for the info Brian.
  4. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Yes, there are some torque-to-yield bolts that need to be replaced. Make sure you know the difference.
  5. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Yes, the adjustment bolt for the alternator belt tightening hub is reverse thread.
  6. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    I should have excluded adjusters - but thanks.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Oh that's not my saying, I just say it alot? :D I heard it a loooooong time ago, and it made so much simple sense it stuck.
    Yes.
    A ring nut on one of the shafts inside the gearbox.
    Yes
    The head bolts, and the bolts that hold the differential together. So unless you are planning on removing the heads from the block, or opening up the gearbox then tearing apart the differential I would worry about those. If I have to remove a ring nut I usually replace those.
    Okay so would clockwise/counter clockwise make you feel better? LOL :p
  8. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    hahaha - everytime I tighten a fastener on this damn engine I keep hearing a faint voice softly wispering 'helicoiled engine' in my head!!! This Ferrari will be the death of me... but I love it.
