Lets see pictures of your engine out service | Page 2 | FerrariChat
Discussion in '348/355' started by Juan-Manuel Fantango, Oct 6, 2021.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    steved033 likes this.
  2. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,458
    Atlanta, GA
    Steve D.
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    So talk about it, no pic of the failed part or just fix it with no thread?
    Funny everyone wanted axerunners pics and were merciless on that.
    Sent using FerrariChat.com mobile app
  4. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    15,025
    Juan
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Oh he is removing the heads. That is not good.
  7. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    422
    H-town...TEXAS
  8. WATSON
    24,025
    WI
  9. steved033
    Apr 12, 2017
    10,458
    Atlanta, GA
    Steve D.
    as long at that lift is bolted down....
    sjd
  10. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    The whole thing is a bit precarious. I realize those rear jack points are where they are, because anything further back blocks the ability to drop the access panels, but the car is a bit of a teeter totter if you don't weigh or tie the nose of the car down. I also used ratchet straps running from the tops of the front pillars of my 4 post lift to eye bolts in the 2x4s in the wall of my garage to keep everything upright.
    Sent from my SM-G975U using Tapatalk
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Why not remove the under tray panels first from underneath and then use the rear most jack points?
  12. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Those jack points below the rear corners of the doors ARE the rear jack points. If you're jacking the car up for something routine, you can stick a jack stand under part of the rear subframe, but if you are dropping the engine, all that subframe is coming out with the engine. When the engine/subframe is out there isn't much left aft of the gas tank...a few spindly bits of tubing holding the rear fenders and tail lights is it.
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  14. chopsui
    chopsui Karting
    Feb 27, 2019
    119
    Austin, Tx
  15. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #41 Ferrarium, Oct 14, 2021
    ugh I am doing that this weekend. Try this, the housing o-rings slide into the groove on the seal housing then slides into the head, the edges where the cover meets the block pinches the o-ring. Use a small file and round those sharp outside edges over a tad and it gets filled with honda bond when you dab those corners. Most leaks come not from the seals but the o-ring nicks when that happens. Also make sure the gasket is not touching the 0-ring it too will cut into it I have read. There are 2 TSB's on how to modify both the valve cover and the seal housing to mitigate the problem I think one was SB 10-31.
    chopsui likes this.
  16. chopsui
    chopsui Karting
    Feb 27, 2019
    119
    Austin, Tx
    Thanks, I'll search for the TSBs. I did smooth out the edges and used honda bond. It took a few weeks before I started noticing the leak. Haven't pulled the valve covers off yet to inspect. Hopefully there is something I can do while the motor is in the car. Otherwise, I'll just live with it for as long as I can stand it. Having too much fun with the car to pull the motor again.
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    If it's in the car what you can do is pull the valve covers off and round that corner then snip off the o-ring and slip another one through with the gap on top and put the valve cover back on after you dab the corners
  18. Juan-Manuel Fantango
    15,025
    Juan
  19. Jasonberkeley
    Jasonberkeley Formula 3
    1,348
    NW Corner, CT
    Yes! I love it! Took me forever to find one, but it is appropriate on this car!
  20. Jasonberkeley
    1,348
    NW Corner, CT
    My car is tracked about a dozen times a year and driven quite a bit locally. This last major from which I posted (from last winter) was after three years, and resulted from a metallic ringing noise I started hearing from inside the front cover literally during the last session on the last track day of the year at Lime Rock. Turns out the fence on the main cam belt drive sprocket had come apart. All of the cam sprockets I had tacked on at the last major three years prior. Good thing I heard it and quickly shut it down.
    Keep your ears open, folks!
    Juan- been following you on here since I started looking to buy a 348 Ch years ago and love your car. We should try to organize some kind of 348 Challenge gathering around a bigger event. It's so rare to see them out and about!
  21. Juan-Manuel Fantango
    15,025
    Juan
    #49 Juan-Manuel Fantango, Nov 10, 2021
    That would be cool! Small club it is. Was fun to see the club racing a few years ago Houghtaling did. . The only issue there was the newer cars are so damn fast, so more dangerous with the difference in speeds. I think these are great rally cars, maybe one day we will see one in some of the rallies that accept newer cars that are now becoming classics.
    BTW isn't this just the best handling best sounding car you have ever driven? So connected to the road.
