Lets see some modified 355s | Page 3 | FerrariChat
Discussion in '348/355' started by madturk, Mar 16, 2015.
  1. PeteyP
    PeteyP Formula Junior
    May 3, 2005
    830
    NJ
    Petey
  2. Oengus
    Oengus F1 World Champ
  3. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
    Wow indeed.
    Not sure why would they do that. The testarossa 12 is not a more powerfull engine than the 355. If I did that I would think that car for sure needs that glass engine cover.
  4. Joshman0531
    Joshman0531 Formula Junior
    866
    Tennessee
    Joshua Seidenberg
    Oh man! That 12 looks angry in the 355.
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,945
    Richmond
    Pete
    That's a 512M motor, quite a bit more powerful than a 355 motor (434hp)...
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,836
    Lake Villa IL
    Enough to offset the weight and higher center of gravity?
    It is different, just doesn't seem worth the effort. (and lack of F1 sound!)
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,945
    Richmond
    Pete
    Given a 512M laps fiorano almost as fast as a 355 despite weighing 300lbs more, I think a 512M powered 355 would be quite a bit faster as the motor/transaxle itself is probably only 100lbs more than the v8.
    Now would I do it? Probably not, I'd go after the 50hp some other way or a combination of power and weight loss to get it.
    Sound wise it's tough to beat a v12 (but if any v8 can, it's the 355), so yeah a sideways move on that.
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    I love this thread
    My creative juices are about to erupt and spew all over my cars
    Soon as I finish these damn other projects LOL
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,836
    Lake Villa IL
    +275lbs and 1 second behind F355 on fiorano correct? Seems like it would be a wash at best with equal weight but not sure?
    It would be interesting to drive just to feel the difference.
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    The V12 is just a cool factor
    If you have a salvaged 355 why not mess with it
  11. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    The flat 12 FTW! I can't imagine a cooler mod, but the jury is still out.
  12. F355Bob
    F355Bob Formula 3
    The TR has so much more torque than the F355 to overcome any weight difference on a short track without a lot of high speed sections of track.
  13. Phil~
    Phil~ F1 Rookie
    3,937
    Potomac, Maryland
    It's not the hp. The 512 motor produces 100 ib/ft greater torque than the 355's V8. You could give the 355 50 more hp and it still would struggle to beat this car (All things else being equal.)
  14. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,836
    Lake Villa IL
    I would take that bet! :)
  15. Phil~
    Phil~ F1 Rookie
    3,937
    Potomac, Maryland
    If the car was built right, sure.
  16. JWeilan
    JWeilan Karting
    Oct 14, 2014
    248
    DAMN.
  17. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,945
    Richmond
    Pete
    Nah, torque is pretty meaningless on a race track where you're spending most/all of your time above the torque peak. From a roll, yeah, but not when you're winding the motor out to redline every gear.
    I think a 355 with 50 more hp would beat a TR engined 355 pretty easily given less weight and lower CoG, the torque just doesn't matter much, especially with the tighter gearing of the 355 transaxle. It would probably cost you as much or more than the TR motor to get 50 more HP out of the 355, though.
  19. F355Bob
    F355Bob Formula 3
    Don't know the layout of the track but if it has a lot of turns and short straights, torque out of the corners is going to help a TR over a 355 I think.
  20. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    thanks for the input.
    please offer the exact specs of your rims and tires.
    rim dimensions, offsets front/rear and tire sizes.
    indeed yours look to fit perfect.
    but no one has really ever confirmed a safe go to setup for 19s on a 355.
  21. nismodrifter
    nismodrifter Formula Junior
    Jun 11, 2008
    548
    YYC/YVR
    Navdeep
    wow, that v12 is insane, love this thread!
  22. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
    Seriously, What is that?? Where are the airboxes?
  23. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,836
    Lake Villa IL
    Just appears to be air filter pods over the throttle bodies (likely with velocity stacks inside).
    Can only be accomplished with aftermarket engine management as the maf sensors are deleted.
    Seems inlet air temps would be a bit toasty but maybe that particular engine deemed it necessary? Not sure.
    Group77racing has a pretty bad ass looking velocity stack/clear plenum setup if you're looking to change the looks of the engine.
  24. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
    What about the air intake?
  25. Dr. Wynter
    Dr. Wynter Karting
    Apr 10, 2013
    136
    Michigan (and NYC)
    Kevin
    +1
