Let's see your favourite 456/550/575 Photo... | Page 177 | FerrariChat
Discussion in '456/550/575' started by Condor Man, Jan 14, 2012.
  1. intrepidcva11
    intrepidcva11 F1 Rookie
    3,232
    Saratoga Springs NY
    Seth
    stretch 456, beautifully executed
  2. 21ATS
    21ATS Formula Junior
    Dec 10, 2016
    988
    Kent, UK
    Alan
  3. efes9
    efes9 Karting
    Oct 22, 2014
    212
    Thanks!
  4. Jon Von Bon
    Jon Von Bon Formula 3
    1,697
    Toronto / Florida
    Jeff
    motts likes this.
  5. timeckart
    timeckart Formula Junior
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
  6. timeckart
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
  7. poljav
    poljav F1 Veteran
    9,996
    SF Bay Area
    Pol J.
  8. timeckart
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
    Christian.Fr, F456M, 308 GTB and 4 others like this.
  9. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    My experience from my Maserati 4200 which had similar coil over shock/springs USB that if you lower the car by lowering the bottom «nut» that holds the bottom of the spring, is that you reduce the spring load/pressure and this causes the car to sit lower. However, the car become less precis on the road and can bottom the shocks more easily. It is very dangerous at very high speeds. I bought the car this way, and I adjusted the bottom nut to give more tension to the spring, and the car rised higher up and became alot more stiff and the road holding was significantly better. It had been «lowered for track use» by Shelton Maserati i Florida just a few years after it was new. The car was extremely dangerous at over 160-200 kph. There would NOT BE POSSIBLE at all to drive at the 290 kph top speed. Just my experience if you did not replace to specific lowering springs.
  10. timeckart
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
    Vteclover302, NE550 and F456M like this.
  11. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I disagree. The suspention is done like that so it won’t look like a saggy old S-class when the har is losses with two persons and full of luggage. The car is perfect when it leaves the factory.
    Makuono likes this.
  12. timeckart
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
    The Maranello was never so deep in front where he came from the factory. The springs at the front decrease with time. Lots of heavy luggage does not fit in the Maranello and the factory also has more ground clearance at the front, so you do not sit.
  13. timeckart
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
    I have thought about it and measured the rear struts and compared with the factory specifications. Since I'm already behind the factory default. So now I will raise the Maranello at the front by 1.5cm.
  14. tazandjan
    39,166
    Ride height is not measured on the struts. 15 mm is quite a bit.
  15. Thad McLaurin
    Thad McLaurin Rookie
    Sep 2, 2018
    8
    Ridgeland, Mississippi
    Thad McLaurin
    My "03 575M F-1. Bot it about 3 months ago with less than 10k miles.
  16. Thad McLaurin
    Sep 2, 2018
    8
    Thad McLaurin
    This is my "03 575 M. I bought the car about 3 months ago with less than 10,000 miles. Love it!
    VColin, F456M, Themaven and 2 others like this.
  17. F355 Fan 82
    F355 Fan 82 F1 Veteran
    Jul 22, 2006
    9,063
    looks great, any interior shots?
  18. Thad McLaurin
    Sep 2, 2018
    8
    Thad McLaurin
    Sorry, no. Interior is tan and perfect.
  19. tazandjan
    39,166
    Thad- Very pretty. Looks just like mine except the interior.
  20. Themaven
    Themaven F1 Rookie
    Nov 2, 2014
    4,361
    Eastdown
    Darius
  21. intrepidcva11
    3,232
    Saratoga Springs NY
    Seth
    yummy!
    Themaven likes this.
  22. Graz
    Graz Formula 3
    Oct 15, 2012
    2,329
    New Jersey and Florida
    Graziano
