Let's start a Red Light District on Fchat | FerrariChat
Discussion in '308/328' started by wernerg, Sep 25, 2006.
  1. wernerg
    wernerg Karting
    Jun 29, 2006
    50
    Danville CA
    Werner Goertz
    The flicker of the red Slow Down light has to catch up with all of us, and I guess you're not a true Ferrari owner unless you've experienced it... and after all the discussions here, maybe we should start a "Red Light District"?
    Last Friday, after 20 minutes of slow to moderate driving, the Slow Down Light started flickering on my '86 328 GTS. I was about 3 miles from my house, so I gently drove her home. Never got a solid light - just intermittent flickers. Oil and water temps absolutely normal, no perceivable loss of power, and as usual, super smooth idle. Back in the garage, no red-hot cat, everything smells and feels normal.
    Took her out again Saturday in 90 degree heat - no light on a short ride. Later that afternoon in about 70 degrees, I saw the faintest hint of a flicker and drove back home right away.
    I will avoid the usual questions beaten to death on other threads (bad ECU, sensors, connectors,...) BUT: what if, for a change, the electronics are actually doing what they are supposed to, namely, warn me about driving too fat, or a cylinder not firing? Judging by the way it idles, I would consider the first option more likely. How do you fix a less than perfect gasoline mixture? (Not that I am going to attempt to fix it myself, btw).
    Werner
    P.S. Apologies if you've seen this in the Technical Q&A section - I am reposting it here...
