let's talk torque wrenches | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by yelcab, Nov 27, 2015.
  1. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,306
    Gold Coast, Aust.
    Patrick
    Spark plugs: finger tight, + 1/4 turn
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,246
    Georgia
    Wade Williams
    At last count I have 13 torque wrenches, between the home shop & work shop, from the first one (Craftsman 1/2 click type) given to me by my step dad for Christmas at age 16 to a 1/2 dial type for pre-load settings. I have a 3/8 Snap On Tech wrench that I like a lot. As noted in a previous post here, battery life was an issue until I started unscrewing the battery cap, now they last as they should.
    Except for the dial type, Armstrong from my Matco guy and the original Craftsman, all mine are Snap On. I have them checked and they are still spot on. I have two split beam wrenches that do wheel duty because backing down is not needed.
    I have two 1/4 for small stuff. They get used a lot. One had a lock ring failure and I had my Snap On rep send it in for repair. It was too old and they had no parts. After a quick phone call to Snap On to confirm they could not fix there tool, the following week my Snap On rep walked in with a new wrench ($260) and said thanks for the business. There was no charge. I had to call because he had only been a dealer for a couple months and had to have a higher up make the call.
    Bottom line, you buy great stuff and it is your for a long time. My son will use these tools after I am gone, he does now, they just stay at my house.
  3. ago car nut
    ago car nut F1 Veteran
    5,552
    Madison Ohio
    David A.
    That is how I torque the centerlock wheels on my TR, Breaker bar marked with my weight on handle. Make sure taper seating is clean.
  4. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Harbor Freight with coupon. On sale for $22.00 each drive. 1/4, 3/8, 1/2. :)
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    Vince, Let me do your engine out service next time, totally on those Harbor Fright torque wrenches, OK? You will rest easy knowing that I torque your crank pulley bolt to 235 Nm, your cam bolts to 98Nm, your CV bolts to 78Nm, your suspension bolts to 80Nm, your engine mounts to 120 Nm, and your cam caps to 10Nm all on those $22 wrenches.
  6. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    495
    Victoria, B.C, Can.
    John Glen Wesanko
    Get a Snap-On torque wrench of applicable range and you're done. I work in aviation and we have Snap-On brand torque wrenches over 30 years old. Mind you they are all sent out for calibration once a year to be re-certified. Why even bother cheaping out on torque wrench ? Amortised over 30 years buying quality becomes very affordable!
  7. f355spider
    f355spider F1 World Champ
    18,059
    Use a torque wrench after using your method, see what you get. I used to do your way (actually), I would tighten with a wrench until the washer started to "yield" or crush), then go about 1/4 turn. I used a torque wrench to see how far off I was....a lot. I could go another 1 to 1 and 1/2 turns to reach correct tightness. I see occasional reports on BMW forums I visit ,of plugs backing out from your technique.
  8. Solid State
    Solid State F1 World Champ
    10,783
    Maximus Decimus Meridius
    Backed out plugs can cause great damage so be careful with whatever method you use.
  9. yelcab
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    The BMW spark plugs do need to be in there tight, right up to spec or they back out and start "ticking" like a valve lifters.
  10. opencollector
    opencollector Formula Junior
    Feb 1, 2005
    424
    CA Central Coast
    Thomas
    Torque wrenches are measuring devices, and metrology is generally the last place to cheap out. Between calibrations one has to trust the instrument.
  11. yelcab
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    #61 yelcab, Dec 8, 2015
    These are now my go-to wrenches. Hope to last for life. I got everything covered from 5Nm to 250ft-lbs and angle. One electronic Gearwrench, 2 split beam Snapons, 1split beam Precision Instruments, and a 1/4 inch Husky clicker. Everyone has been checked with a Torque meter to be accurate 2-4%.
  12. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    LOL
    Interesting you say this. Happened to me once from a dealer service and one of those things sawed its way through the threads. Needed a helicoil that cracked the head. But that's another story.
