360 - LH Radiator Fan Not Working, Works With 12v Applied Direct | FerrariChat
360 LH Radiator Fan Not Working, Works With 12v Applied Direct
Discussion in '360/430' started by Kendall, Jul 29, 2025 at 3:10 PM.
  1. Kendall
    Kendall Rookie
    24
    Kendall Torrejos
    Hi everyone, trying to work out this LH Radiator fan issue. I applied 12V Directly to the fan and its working properly. I was running MaxxiECU Diagnostics and forced the temp up to 110 Degrees C and the fan still did not come on. Checked the Large 30amp fuse in the front boot, tested R28 with 12v and its clicking, and tested the relay on the RH Fan with 12v, its clicking. I have the Thermostatic Switch out and I am testing it for resistance using a multimeter and boiling water. I am not getting any reading besides 1. This includes ice water, and boiling water. I have tried the multimeter on all of the OHM settings. When I tap the multimeter prongs together the reading zeros out. I wanted to check my method of testing the switch here to verify my testing method is correct.
    When I removed the switch, coolant came out, so I believe there is no air in the system and the coolant level is correct
    Thanks in advance.
    Kendall
  2. Qavion
    Qavion F1 World Champ
    14,333
    Ian Riddell
    #2 Qavion, Jul 29, 2025 at 4:04 PM
    That's a strange value for any of the contacts. Are you sure your meter is ok? Try it on the lowest ohms scale.
    Here's a schematic of the switch.
    As the temperature rises, pins 1 & 3 should go from open circuit to closed circuit. As the temperature gets higher, contacts 2 and 3 should go from open circuit to closed circuit. Contacts 1 & 3 are the ones which control the LH fan.
    Even if the switch wasn't working, you should get the fan to run with the HVAC refrigerant pressure at 15bar. With a warm cabin, turn the temperature to full cool.
  3. Kendall
    Kendall Rookie
    24
    Kendall Torrejos
    Thanks for the response and the schematic.
    I left out that the RH fan runs with the AC on.
    After seeing the schematic I ran a jumper between pins 1 and 3 and pins 2 and 3 and was able to get both fans to fire.
    I have another multimeter at work that I am going to test tomorrow.
    My thoughts here are that I have narrowed it down to either air in the system and coolant isnt hitting the sensor properly, or the sensor in bad.
    Both seem like manageable fixes at this point.
    If anyone else has any feedback on my method it is appreciated. My extent of previous multimeter testing knowledge is just checking for power, so I never use any of its other functions, and was trying to learn from a youtube video.
    Thanks again!
    Qavion likes this.
  4. Qavion
    14,333
    Ian Riddell
    Well, your probes aren't exactly precision devices. Are you sure they aren't shorting out?
    With a cold sensor, all the contacts should be showing infinity on the 200 ohm scale.... however that is represented on the display. "OL"?
