LH Radiator replacement options | FerrariChat
Discussion in '348/355' started by mshobe, Nov 8, 2018.
  1. mshobe
    mshobe Karting
    Mar 28, 2015
    112
    Seattle-ish
    File this under "while we're in there…"
    You may recall my radiator pipe leak fix-in-the-field earlier this year. Oh, the fun we had.
    I still haven't gotten a sleeve of silicon radiator hose grafted onto the pipe, which I'll cut right at the trouble spot, to patch the leak, but that's because life has been interfering – no technical reason.
    However, I've noticed that the radiator itself doesn't look very good. It's always had some corrosion, but there is crusted coolant at the connectors, and I'm nearly certain it's the original unit from '95.
    Ebay has a few aluminum replacements (see here) and Ricambi shows their aluminum replacement as out of stock. Not sure if they're all coming from the same place in Germany, or what.
    Anyone have any insight on where the best part source is these days to stooge this, other than some poor soul parting out a pristine engine bay? (Rather not talk about that.)
  2. jqpd99
    jqpd99 Formula 3
    2,449
    Ottawa
    DFO
    Do a search on Saldana radiators as a potential other source for these...
    DF
  3. F355Bob
    F355Bob Formula 3
    mshobe likes this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,448
    San Carlos, CA
    Mitchell Le
    I would buy from Ricambi, when they are back in stock. Prefer aluminum over the plastic caps ones...
  5. mshobe
    mshobe Karting
    Mar 28, 2015
    112
    Seattle-ish
    Thanks all. Makes me wonder if the Ricambi part is sourced from Saldana.
    phrogs likes this.
  6. chrisj951
    chrisj951 Karting
    Feb 18, 2015
    204
    Metro Atlanta
    Just spoke to Saldana and they did say they make Ricambi's product.
    mshobe likes this.
  7. yelcab
    Nov 29, 2001
    13,448
    San Carlos, CA
    Mitchell Le
    I know for a fact that the aluminum one does not fit the 355 challenge.
  8. mshobe
    mshobe Karting
    Mar 28, 2015
    112
    Seattle-ish
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Send one to Ron Davis in Arizona, he does all my rads now best and good prices
  10. phrogs
    phrogs F1 Veteran
    7,324
    Michigan
    I have a brand new lh radiator. Send me a private message if interested in it.
  11. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  12. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Changed both in my 355 and I used Saldana, way better and cheaper than OEM. Ricambi did not carry them at the time so I ended up purchasing them from Euroquipe in Illinois. They cost about 900$ IIRC
  13. RAC911
    RAC911 Karting
    Jun 8, 2006
    206
    Arizona
    Ralph Cacace
    Were your radiators leaking before they were replaced?
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  15. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Yes, one blew out and I changed it and then about a year latet same thing happened to the other so now I have the upgraded Saldana ones on both sides.
    Was very impressed with the build quality. The OEM Ferrari ones looked like cheap plastic and were priced higher than these. Honestly a no-brainer as a replacement for any 348/355 owner.
    308 GTB likes this.
  16. 308 GTB
    308 GTB F1 World Champ
    11,673
    New Jersey
    Barry Wolinsky
    I too upgraded to Saldana radiators two years ago when, at Sebring, a chunk of rubber tore through my right wheel well liner screen knocking off two fan blades and damaging the OEM radiator core. Seeing how cheaply it was made, I decided to upgrade both of my radiators. Daniel at Ricambi America didn't have the Saldana radiators in stock at that time so he referred me to Euroquipe too.
    Thank-you again, Daniel!
