Li-ion batterij oplader nodig in Den Haag | FerrariChat
Discussion in 'Holland/Belgium' started by walnut, Oct 14, 2014.
  1. walnut
    walnut F1 Rookie
    3,091
    Maryland, USA
    Rich
    Is er iemand in / bij Den Haag hebben een acculader voor Li-ion batterijen die ik kon lenen?
    *Gelieve te excuseren mijn slechte gebruik van de Nederlandse taal, ben ik nog aan het leren.*
    It is probably easier for me to explain why in English. I am having issues with my motorcycle's charging system and in order to diagnose what is wrong I must charge my battery so I can get the engine started to test the rectifier and stator. I am only in the Netherlands for about 9 more months so I would prefer to not to have to buy an expensive charger for the week or so (hopefully only a week) that I would need it.
  2. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    You can charge it using a regular charger
    Max voltage should stay under 15V
    If uncharged voltage is under 10V the battery could be lost
  3. walnut
    walnut F1 Rookie
    3,091
    Maryland, USA
    Rich
    I had no idea. I will pull it from the bike today and hook it up to the charger that I have borrow from my co-worker which only indicated it was for use with Lead Acid and AGM batteries.
    Thank you.
