458 - "Lifetime fill" for... coolant? | FerrariChat
458 "Lifetime fill" for... coolant?
Discussion in '458 Italia/488/F8' started by Need4Spd, Feb 20, 2019.
  1. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I don't believe in "lifetime" fills for anything, much less coolant. Among other things, don't corrosion inhibitors give themselves up over time, so as to eventually leave you with no corrosion protection, even in a closed system? Yet, Ferrari dealer insists there's no reason to change my coolant. Even on a 2010 going on 9 years! Anyone else have this told to them? Did you insist anyway?
    hgoodwiniii likes this.
  2. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,816
    You can refer to your service warranty booklets.
    I thought it was supposed to be changed every two years
  3. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    I agree that any fluid can't really be "lifetime".
    Therefore I had the dealer change the coolant at the 5 year mark, and plan to do it every 5 years.
  4. Solid State
    Solid State F1 World Champ
    10,445
    Maximus Decimus Meridius
    You are correct. No lifetime fluids for anything. If you have a 2010 and the brake fluid and oil needs to be done anyway, I'd ask for every fluid in the car changed. I did that to mine and feel much better and so does the car! They said no problem even gear and trans fluid. Cost is lower than expected. Don't forget the power steering fluid. They do these changes for those who ask. My specialist said he'd do it to.
    The thing about coolant is that the degrading formulation is exposed to various metals and will cause corrosion that, once started needs acids and flushes to get them clean if at all possible and those chemicals carry additional system risks. Good luck.
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Thanks. Yes, all other fluids have been changed annually since I got the car, and the last couple times I asked about coolant, the dealer said something about lifetime and didn’t seem interested in doing it. This time I’m going to a trusted independent and getting it done.
  6. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,248
    Mel
    Need4Spd and PJxxx like this.
  7. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Good idea. But probably best to start a separate thread.
    Melvok likes this.
