Lift a 328 with a distrilift? | FerrariChat
Discussion in '308/328' started by gigaleff, Mar 29, 2010.
  1. gigaleff
    gigaleff Rookie
    Feb 27, 2008
    47
    Switzerland
  2. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Nope. The rockers have very little structural rigidity. You'll simply crush them and then your car will look like crap from the side and down low.
    There are proper lift points where there's a structural member of the frame - you'll see where they are by looking for a (usually crushed) jack receiver location point, just behind the front wheel and just ahead of the rear wheel. If you lift anywhere else you'll hear the sound of deforming metal....
  3. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    +1
  4. JV's89
    JV's89 F1 Veteran
    7,289
    Pittsburgh, PA
  5. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Forget what it may do to the car --- what will it do to YOU !! That thing looks sketchy as hell !!! I wouldn't go anywhere near a car that was propped up on one of those things...
  6. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
  7. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,312
    Southern New Jersey Shore
    Phil
    That looks like just a regular scissor lift a lot of folks here use. There are half a dozen manufacturers/retailers...Bend Pak, Snap On, Greg Smith Equipment, etc. They are hydraulically operated, and weight about 1,000 pounds. Quite stable, and convenient. Notice the two pistons in the photo, the motor is mounted away from the unit on a stand that also enables you to roll the lift around (assuming you have the upper body strength to do so).
    Phil
  8. MarkJ
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    Thanks, Phil. I'll look into it.
  9. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    #9 viper_driver, Mar 31, 2010
    My rockers were all bent up when i got my car, there's really nothing supporting them.
    I mostly bent them back just using my hands. They're about as solid as trying to jack up your car using the door or front fender.
