Lift installed! | FerrariChat
Lift installed!
Discussion in '348/355' started by Superjet2099, Dec 23, 2017.
  1. Superjet2099
    Superjet2099 Rookie
    Apr 23, 2017
    38
    Moyock nc.
    Schatten, Yassa, steved033 and 2 others like this.
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Just dont drop the car. Seen it happen so be carfull
    Superjet2099 likes this.
  3. Qavion
    Qavion F1 World Champ
    14,349
    Ian Riddell
    Nice... How tall are the pillars? Just wondering if that would fit in my garage.
  4. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Nice! Always do a shove test. Always.
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Qavion likes this.
  6. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    From the specs:
    • The floor on which the lift is to be installed must be 4-inch minimum thickness concrete
    • Must have minimum comprehessive strength of 3,000 PSI
    I'm guessing you could drill the floor to determine thickness, but how do you determine the comprehessive stength (if the floor is pre-existing for years, prior to install)?
  7. INRange
    INRange F1 World Champ
    12,591
    Virginia/Florida/Caymans
    JD
    How far apart did you set the supports?
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Nice!!!
    I love mine, stout little lift and love the lift pump setup.. I have bolt patterns in 3 different spots around the house.
    jrs likes this.
  9. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,022
    NE FL
    Ken
    I about poo'ed my self with my car on the lift with the engine out... I was lifting a radiator up to remove it, and the car lifted of the rear pads about 2 inches.
    Be very careful and I highly suggest weights for the rear.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
  11. Qavion
    14,349
    Ian Riddell
    Thanks, Meister.
    I'm just wondering what the relationship is between the height of the pads and the height of those rods which protrode from the top of the pillars.
  12. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    3000 psi concrete is/has pretty much been the building standard for years
  13. tres55
    tres55 F1 Rookie
    3,572
    Canada
    What's your ceiling height in that garage?
  14. Superjet2099
    Superjet2099 Rookie
    Apr 23, 2017
    38
    Moyock nc.
    I think I put them 130 inches apart but I’ll double check when I get home
  15. Superjet2099
    Superjet2099 Rookie
    Apr 23, 2017
    38
    Moyock nc.
    8.5 ft
  16. Superjet2099
    Superjet2099 Rookie
    Apr 23, 2017
    38
    Moyock nc.
    It only extends about 8ft the total height it goes up is about 4.5 feet off the ground I’ll post pics with the 348 on the lift later this week
    Qavion likes this.
  17. Superjet2099
    Superjet2099 Rookie
    Apr 23, 2017
    38
    Moyock nc.
  18. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    NICE! Dave Rocks had a very good write up on lift points for the 355. On my asymmetric two post lift I put it on the lift backwards. I also have some tall jack stands that can be placed under one end for additional support, especially with pick up trucks and longer cars. If you do the shove test, don't do it at full height!!
    It looks like your lift is low enough to fit under the car, if so that is real nice. I have to raise my car a bit to get the arms under.
    A lift is the single best auto tool investment I have ever made.
  19. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Why did you have to cut that area out? It needed to be repaired?
  20. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,128
    Atlanta, GA
    Steve D.
    Likely was that his slab didn't meet the minimum thickness requirement.
    sjd
  21. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    I too have a MaxJax and it was a blessing to have when doing the engine out work.
  22. Jasonberkeley
    Jasonberkeley Formula 3
    1,348
    NW Corner, CT
    Do any of you folks with MaxJax ever actually unbolt them and wheel them off to the side to keep your garage more clear? How long to take down and set-up after the initial install?
    Im looking to get a four post lift with jacks on it which will be primarily for storage, but also basic repairs and maintenance. Would like a two post lift as well for more serious repairs and maintenance, but i'd lose the ability to park three wide in my garage if I installed a more permanent / full height two poster.
    Any feedback from those who have installed, removed, and reinstalled their maxjax lift would be appreciated.
    Thanks,
    Jason
  23. vjlax18
    687
    Nottingham, MD
    I do quite often. Right now I have one installed and one uninstalled to give more room in my garage. It's amazing how much space lifts take. Also, I leave my 348 on the lift for extended periods time while I'm working on it. I think the engine out service took 4-5 months and the car was on the lift the entire time. (My wife and I had out second son in the middle of the engine out)
    I can unbolt the lift in a few minutes and I have the spacers and the floor marked so that I don't have to spend much time re-leveling when I bolt them back down. Essentially, it takes less time for me to install the lift and get a car in the air than it does moving a jack around a car and putting jack stands under each corner.
    Schatten likes this.
  24. Superjet2099
    Superjet2099 Rookie
    Apr 23, 2017
    38
    Moyock nc.
    #24 Superjet2099, Dec 29, 2017
    the concrete was only 4 inches max jaxx requires 4.5 inches of concrete. they say it only needs 4 but when you get down to installing the anchors it needs 4.5 inches. i also went with 5000 psi rated concrete reinforced it with rebar and poured about 3 inches under the existing slab. Im a bit paranoid about a car falling on my head i love my Ferrari but im not looking to die in it or under it! (Look at step 4 in the picture from the manual)
  25. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,777
    Lake Villa IL
    If min thickness is 4in why do you feel it needed 4.5? They say to drill 4.5in so the anchor is flush on a thicker slab but on 4in slab just drill all the way through.
