Lift pads / cradles for MoHawk A7 lift | FerrariChat
Discussion in '348/355' started by Dave rocks, May 13, 2014.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #1 Dave rocks, May 13, 2014
    So, I have OCD :D
    The lift I bought came with steel serrated pads (pretty dumb). Even if I wanted to, I cannot use them since the arm positions don't match where I wish to lift.
    That said, thanks to Mitch, I used hockey pucks and just placed them on the lift arms.
    The lift has a primary and secondary arm so there is a height different of .6875".
    I also am not thrilled with the pucks just sitting on the arms so I decided to design and build these cradles. These will hold the pucks in a recess and will put them both at the same height as well as allowing the cradle to side along the length of the arm. I've added set screws so I can clamp this in position if I like.
    The one for the larger arm is offset since Mohawk has a bracket (I'll remove) to prevent the secondary arm from being pulled out to far. I'll come up with another way. They also reinforce the end of the arm so I wanted to get the puck to the very limit and I needed clearance for the reinforcement.
    I do plan to check some dimensions before I finish (clearances to the body, etc.)
  2. Ajax de 1e
    Ajax de 1e Formula Junior
    Feb 21, 2014
    897
    Holland
    Steef
    OCD, as in 'osteochondrosis dissecans'? :D
    Very common at race-horses :)
    Nice work btw!
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    SoCal LA/OC/New Mexico
    Tim Dee
    I'm sure its real easy to get off the shelf stuff
    Also a pinch weld clap is insanely convenient tool, design one of them
    Yes I would make the pads height adjustable, that will come in extremely handy later when you try different things with the lift
    BTW, get CATIA a real program LOL
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    #4 SoCal1, May 13, 2014
    just for sheeztz giggles, this was the last lift I purchased before retiring, 3 of them
    Not a conventional lift but an absolute necessity for lunatic fringe stuff we were doing at the time.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I want the pads as low as possible to I don't have to block the wheels to get the arms under - I know I will with the F car but my BMW does not need it. I only have one other car I plan to lift - I post the photo after I pick it up this weekend :)
    And Solidworks is way better than CATIA crap LOL.
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    Just have them "screw in" so you have min height but can adjust it up, sometimes you need .250 extra on an arm.
    Solidworks Hmmmm Oh yeah the old ProE kernal :)
    I learned on Catia many moons ago and cant even pad something much less seta restrength in solidworks. I should take a coarse one day.
    We use it due to we can design, model and create NC code and send it to the machine without moving more then 20 feet. Rapid for us.
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Nope Tim, it's the NX Kernal. I plan to get NX Cam and maybe down the road switch to NX CAD so we can use one system. We use MasterCAM for milling and Esprit (garbage) for Mill Turn.
    I hear you on the adjustments but I'll probably just get some varying thickness rubber sheets.
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    Well it's good to see they are still killing us in this area We have post processor plugin custom made from a guy in Houston, cant remember his name. The game keeps changing and not getting much better LOL
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You're really overthinking things.
    In the "real world", I have an assortment of wood blocks for the various problems encountered lifting exotic cars. Nothing fancy but it's simple, flexible and gets the job done. There is no single thing that will work for every car so there's no point expending a lot of effort trying. Trust me that the blocks don't need to be fastened to the lift arms. With a 3000 pound car on it nothing is going anywhere.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Tim,
    I know you are correct but you apparently did not read that I have OCD :D
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    I did, have it also plus add my ADD to the stew LOL
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Wrong Tim, Tim LOL
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    see what I mean
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #14 Dave rocks, May 13, 2014
    Well tonight I made some adjustments to the lift so the locks engage on each side at exactly the same time. I also made adjustments since the locks would re engage going down - fixed that. But, to get the car perfectly level side to side, I need to raise one column 5/8" so I'll need to shim the base plate.
    I backed the 355 in place to check positioning and such. Turns out the 355 needs at least 2" of clearance from the top of the contact pad to the lift arm. That said, I'll need to revise my design a bit. I'm going to just make a riser piece.
    I'm pleased with the positioning though. I'll have 4 feet from the back of the car to the garage wall. Plus I can open the doors freely with no chance of hitting the column.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #15 Dave rocks, May 13, 2014
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #16 Dave rocks, May 13, 2014
    I'll probably position the car backwards another inch or two.
    I was actually almost able to get the arms under the car without blocking it up.
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    We always put some foam padding on the uprights edge just in case a door can make its way close enough
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I do have foam door guards that came with the lift. Just have not installed them yet.
  19. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    This may be a little late, but you can make adjustments by shimming under the top of the hydraulic cylinder. When I installed mine, one side would engage the top lock on one side but not on the other. I made a new shim which fixed the issue. The instructions are in the manual (although a little cryptic). The shims can be purchased from Mohawk or made on a lathe.
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    That's exactly how I did it.
  21. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    39,711
    Huntsville, AL., USA
    Andrew
    Where's Mike (AceMaster)? He'd love the hockey pucks solution! :D
    All the best,
    Andrew.
  22. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    Lol, nice....Andrew, I did get your PM too by the way :)
  23. NeuroBeaker
    Moderator
    Oct 1, 2008
    39,711
    Andrew
    :D
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #24 Dave rocks, Jul 10, 2014
    I've been too busy to make all the parts for my lift cradles but did have some time this evening to finally get the 355 on the lift. Needed to raise the back with a floor jack to set the rear wheels on boards to swing the lift arms underneath.
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #25 Dave rocks, Jul 10, 2014
