348 - Lift point dimensions | FerrariChat
348 Lift point dimensions
Discussion in '348/355' started by Huskymaniac, Apr 4, 2021.
  1. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Does anyone know the width and depth between the 4 corners representing the lift points. I am shopping for a lift again and need these dimensions to make sure what I buy can access them.
  2. Qavion
    Qavion F1 World Champ
    14,394
    Ian Riddell
    308 GTB likes this.
  3. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
  4. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Yes. I got under there today, or tried, and got a rough estimate of 35" front to back and 58" side to side. I originally missed that there were those inverted U-shaped jack points on the back too.
  5. Qavion
    14,394
    Ian Riddell
    According to the manual, the wheelbase is is 96 inches. I didn't realise the jacking points were so close to each other (compared to the wheelbase). The front track dimension was pretty close... 59 inches.
  6. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,026
    NE FL
    Ken
    You really should never use the factory rear location when on a lift... It's just too unstable to wrench on.
    Pushing the rear arms ~18" further back to the frame location provides much more stability.
  7. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Does that prohibit you from dropping the engine? Maybe it make sense to get a couple of those column style jack stands to put under the rear frame points after it is jacked up?
  8. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,026
    NE FL
    Ken
    I suppose some people might use the cradle as a jacking point, but they're actually points on the frame before the cradle that you use. They have no effect on dropping the motor.
