Lift Recommendations for Garage | FerrariChat
Discussion in 'Detailing & Showroom' started by dherman76, Jul 8, 2018.
  1. dherman76
    dherman76 Formula Junior
    Feb 25, 2004
    601
    Boston
    Darren Herman
    Looking to add a lift to my home garage. Not sure if I should go with 1, 2, or 4 post lift. Any recommendations? Would be to store my sports car or daily driver (sedan).
    I have about 9.5 feet of clearance before hitting the garage door rails.
    Thanks in advance!
    D
  2. Graz
    Graz Formula 3
    Oct 15, 2012
    2,327
    New Jersey and Florida
    Graziano
    Highly recommend American Cusrom Lifts. They make a single post lift that is wonderful.
    Ryan... and dherman76 like this.
  3. dherman76
    Feb 25, 2004
    601
    Boston
    Darren Herman
    Why did you go with Single Post? Purely curious.
  4. Graz
    Graz Formula 3
    Oct 15, 2012
    2,327
    Graziano
    I originally had a 4 post lift and found it to be too intrusive and quite frankly not too secure. The single post has a platform and base that is bolted into the concrete. It truly is commercial grade quality. The car is suspended in air with only one post. The ramps are 24” wide and easy to drive on and off. For my purpose which is storage and detailing the cars it’s perfect.
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Make sure you do some measuring first. My garage is about 9.5' and I can only do two sports cars like ferrari/lotus, lotus/porsche stacked. I could never get a sports car on top and an suv on bottom and would think its it'd be pretty tight with a sedan.
  6. GTO Joe
    GTO Joe Formula Junior
    997
    Charlotte, NC
    Joseph Troutwine
    You mentioned that you have 9.5' to the door rails. Keep in mind you can move them up closer to the ceiling with a special package and also you would want to consider a jack shaft opener to clear the center area. This will give you additional height and open your possibilities. I have done this in several garages I have had over the past years with four post lifts. PM me if you need more specifics.
    Keith Darby likes this.
  7. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    Do you plan on dropping engines out of any of your vehicles?
  8. syata
    syata Formula Junior
    Feb 23, 2017
    425
    Ok, I get the lifts you can drive on and then possibly store another vehicle under the lifted one. You can work on the vehicle that is on the lift...limited work.
    If you want to work on the car that requires taking the wheel(s) off then a lift with the four arms that go on the frame is desired. I am mainly reading lifts you can drive on. The lifts with the arms you can get as one post and four posts. With the four posts you can store another vehicle under the lifted car.
    Reason I ask, I have a 328 and Mondial. To replace the battery on the Mondial I need to take the from passenger wheel of. To do belt changes I need to take the rear passenger wheel off with both cars.
    Somehow I would rather get a lift I can perform the maintenance on the car.
    Any thoughts?
  9. Bdel
    Bdel Formula Junior
    Nov 3, 2003
    358
    Hollis, NH
    Bruce
    Most four post lifts have a jack tray which can slide anywhere on the lift. You can place a bottle jack under any of the corners while on the lift
  10. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    I am looking for lifts for my garage (and the new garage I'm building). Does anyone have any experience with installers in the Phila area? Thanks
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,674
    Central NJ
    Dominick
    Pm sent
    Sent from my moto x4 using Tapatalk
  12. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
  13. SaratogaCA
    SaratogaCA Formula Junior
    Sep 11, 2016
    319
    Saratoga, CA
    Sam T.
    I took a quick look at their website, but could not find a quote for the one post lift. Can I ask how much you paid for yours?
    I know there are some variations for options, etc. But it would be nice to have a rough ball-park figure.
    Thanks!
    - Sam in Saratoga
  14. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,514
    Avvocato
  15. mrgreystone
    mrgreystone Rookie
    Feb 20, 2019
    4
    Alex Wood
    I have the Bendpak in a shallow pit in my garage. It works great, not outrageous cost.
    What you are seeing is a AL cover which I can drive/walk over and use as a table/work surface. The lift is a Bendpac with four articulating arms which can be positioned under the chassis lift points.
    Here is a photo of the lift without the cover. The yellow arms with the round black pads can be positioned to the lift points on the car.
  16. colombo2cam
    colombo2cam Formula Junior
    Jan 31, 2019
    840
    Ted
  17. colombo2cam
    Jan 31, 2019
    840
    Ted
  18. Jasonberkeley
    Jasonberkeley Formula 3
    Apr 23, 2017
    1,327
    NW Corner, CT
    Jason Berkeley
  19. Jasonberkeley
    Apr 23, 2017
    1,327
    NW Corner, CT
    Jason Berkeley
    How high can this lift the car? How deep does the pit need to be, and how thick does the slab need to be at the bottom of the pit to support the lift. I like this alot- very clean.
  20. colombo2cam
    Jan 31, 2019
    840
    Ted
  21. colombo2cam
    Jan 31, 2019
    840
    Ted
  22. technom3
    technom3 F1 World Champ
    18,036
    Phoenix AZ
    Justin
    I have a mobile version of this... where you don't have to cut into the concrete at all. and you can move it and put it away or you can just move it over. They are only like 1700 bucks. Lifts the car about 3 feet or so. Pretty excellent
    flash32 likes this.
  23. colombo2cam
    Jan 31, 2019
    840
    Ted
  24. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,674
    Central NJ
    Dominick
    Me too .. with lower cars you need to build runwwys
    My has a 48 lift
    Sent from my SM-T380 using Tapatalk
