Lifts for garage | FerrariChat
Lifts for garage
Discussion in '458 Italia/488/F8' started by Ddushman, May 17, 2023.
  1. Ddushman
    Ddushman Rookie
    Dec 18, 2021
    47
    Hi,
    I'm about to add a lift for my F8.
    Wondering what lifts everyone is using and would recommend or not recommend. Looking for some advice from the experienced lift folks here. TIA.
    Dave
  2. AD211
    AD211 Formula 3
    Owner Rossa Subscribed Silver Subscribed
    Aug 19, 2017
    1,232
    South Carolina
    Andy
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    I am using two atlas lifts .. two different locations .. no issues .. can't compare to others since only know these
    At the time very cost effective ..
  4. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    I have a bendpak, I'm selling it as I moved, are you near Houston? I moved to OKC
  5. Mrpseudonym
    Mrpseudonym Formula Junior
    602
    Sydney, Australia
    Adding a part 2 q, can anyone recommend a lift that also allows you to jack the car up to change wheels while car is on the lift?
  6. AD211
    AD211 Formula 3
    Aug 19, 2017
    1,232
    South Carolina
    Andy
    I added this…
    https://www.wildfirelifts.com/bridge-jacks
    DefunctNeurons and MANDALAY like this.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    The atlas has a sliding jacks ..ri35
    The other way is to put quick jacks on a lift
    Mrpseudonym likes this.
  8. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,644
    SF Bay Area, CA
    Ruben
    I’ve used a Bendpak HD9 (standard width model) for about 3 years - have been super happy with it. Fits the Speciale with ease - super solid.
    SD455TA and Mrpseudonym like this.
  9. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,644
    SF Bay Area, CA
    Ruben
    Bendpak HD9 also has bridge jacks that can be optioned.
  10. SD455TA
    SD455TA Formula Junior
    I also have the Benpak HD9 for about 13 years now and am happy with it as well. I like that it is certified and that it has locks when you lower it into position for peace of mind. I did buy the aluminum entrance ramps that do not droop in the front which gives you plenty of clearance to park a car underneath it when it is raised. It does fit the Speciale with ease. I only wished it wasn't made in China.
    Il Tifoso likes this.
  11. ACSATCO
    ACSATCO Formula Junior
    Dec 23, 2020
    361
    AJC
    jc1 likes this.
  12. SD455TA
    You might want to take a look at some extended ramps. The ones you have are very small and it looks like you could bottom out when accessing or pulling off the platform. I would say my entrance ramps are about 20 inches long and it makes for a real gradual change of grade.
  13. ACSATCO
    Dec 23, 2020
    361
    AJC
    those actually came with the lift and they have a special lip that is engineered to fit into a locking mechanism that keeps them in place once weight is on them. they are easily 24 inches, i think more. no issues ever, just about every type of exotic so far and no scraping. sometimes i even forget to raise the vehicle front end lift and still no issues
    05F430F1 likes this.
  14. Ddushman
    Ddushman Rookie
    Dec 18, 2021
    47
    Hi, yes I'm in Dallas. Not sure of the logistics to move and install so have not considered used. Which Bendpark? 220Motor?
  15. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    BendPak HD-9XW 90001b 4 post home lift-220v
    I had these guys install it
    https://mtfequipment.com/
    I think they will drive up to dallas to install it....
    I paid 8980$ and that includes the 1000$ install.
    I got the aluminum center plate and the 48" aluminum ramp
    I had the lift for less than a year, I got married and am moving to OKC
    Will be selling the house in Bellaire/Houston sometime in June
    2819481657 - Ricky
  16. timba
    timba Formula Junior
    Aug 20, 2012
    258
    Nor Cal
    Tim
  17. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,644
    SF Bay Area, CA
    Ruben
    Good point on the extended aluminum ramps… I have them as well and the extra length really helps with low clearance cars.
    SD455TA likes this.
  18. SD455TA
    I went back and measured my ramps and they are 38" and I would highly recommend something like that for anyone with small ramps like the ones you have simply for safe keeping if nothing else.
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    Look into the race ramp ones specifically made for the lift you have ..they weight nothing
    Monteman likes this.
  20. ACSATCO
    Dec 23, 2020
    361
    AJC
    my ramps are 36" and theres not one production car i can think of that will not make it up and down easily. and just about everything has been on there with zero issues. Lambos, Ferraris, Porsches, McLaren's, all of them, all the track focused low to the ground cars, no issues
    SD455TA likes this.
  21. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    I was super paranoid, I did the 48" aluminum ramps + the 5" Raceramps
    https://www.raceramps.com/
    I had a very bad elevation on my driveway which necessitated the use of multiple ramps to get my super low cars into the garage and onto the ramp
    The biggest ******** is the street still floods.... :(
  22. Thecadster
    Thecadster F1 Veteran
    7,650
  23. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    I went with the most impressive unit I could find... It's hydraulic and lacks cables. I have had bad experiences with cables so stuck with pure hydraulic. Plus, no cables going from side to side. I had a hard limit of 10' for the lift and that limited me to just a few choices. The Mohawk was pretty obvious. $10k all in (three years ago). I installed it myself with a minimum of hassle. With my 360 on the lift, I have a clear 6' under the car.
    Mohawk System 1A (10,000 lbs.)
    https://mohawklifts.com/automotive-lifts/2-post-lifts/system1/
  24. Nsd991
    Nsd991 Formula Junior
    Jul 19, 2012
    541
  25. KZEVO
    KZEVO Formula Junior
    Jul 25, 2021
    292
    I just had a single post installed. Easy to operate and opens up a lot of room in the garage with only one post.
