Light on for 5 days =flat battery..now what? | FerrariChat
Discussion in '360/430' started by dias7777, Sep 8, 2014.
  1. dias7777
    dias7777 Karting
    Jul 31, 2014
    108
    Sorry for the newbie question but now that the bat is flat how do I jump start it? Will I need a new bat? Thanks
  2. tazandjan
    39,073
    Do not jump start the car. Use the battery disconnect switch and then connect a charger to the battery and charge. Reconnect the battery and do a run cycle. Every time you deep discharge a normal lead/acid battery, it slightly degrades the battery, but no telling how badly. You will know fairly quickly if you need a new battery. If you have an absorbed glass mat (AGM) battery, deep discharge will not do any damage.
    Jumping a Ferrari can lead to all kinds of ECU problems.
  3. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    Don't jump start the car. Connect it to a battery charger and wait for the battery to get recharged. Then, drive it!
  4. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,726
    Just East of Weird
    Bob
    What those guys said...
    Search for my recent post: "Did my glove box kill my battery" Terry and others have some good advice
  5. dias7777
    dias7777 Karting
    Jul 31, 2014
    108
    Thanks so much guys!!!
  6. dias7777
    dias7777 Karting
    Jul 31, 2014
    108
    Sorry Taz- whats a run cycle? Lol
  7. tazandjan
    39,073
    Here you go. Got tired of writing it so saved it to hard drive:
    Run cycle.
    Turn battery disconnect switch off and turn off all accessories (stereo, A/C, etc).
    Let engine get completely cold or wait at least 30 minutes.
    Insert key in ignition and leave for 30 seconds.
    Turn ignition to on and leave for 30 seconds.
    Turn ignition off and leave for 30 seconds.
    Turn ignition on, wait for Check OK, and start.
    Let idle with no input whatsoever for 10 minutes.
    Turn accessories back on and drive gently for 10-15 minutes at least.
    You will have to insert stereo code, if required.
  8. dias7777
    dias7777 Karting
    Jul 31, 2014
    108
    Awesome thanks so much. A fellow ferrari member from this forum was kind enough to come over with a CTek charger so will take the battery off and hopefully let it charge for 1-2 hours (?!). I will then follow that run cycle
    Thanks Taz
  9. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    If it's a CTek charger (Like my 7002) I would leave it on overnight, or until it shows a full charge, before doing anything. For a 90 Ah battery it shows in the manual it's a 11-13 hour charging time to recondition a deep discharged battery.
  10. dias7777
    dias7777 Karting
    Jul 31, 2014
    108
    Thanks for the advice I will leave it overnight then.How can I tell If my battery is an AGM battery?
  11. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Just like everyone said - never jump start a Ferrari. Turn battery main switch off. Recharge the battery via battery terminals to full charge. Dont use max current as you dont want to cook your battery. Use slow charge or low amp.
    Once the battery is fully charged - remove battery charger. Turn main battery switch on, then do a system reset as Terry has recommended.
    Dan
  12. Jeffs360spider
    Jun 25, 2014
    35
    Northern New Jersey
    Jeff S
    I keep reading this comment "turn main battery switch off". What does that mean? I have a CTEK charger and would like to connect it to trickle charge but I don't know how or what to do. I am so concerned about touching or connecting the wrong thing and blowing up the car.... joking.... but just a little. I have an 04 360 spider. Does anyone have a video or can help me in setting up the CTEK. I do not have the terminals that came with the CTEK as I put them on my motorcycle and forgot to take them off when I sold them. Should I get new terminals?.. Please help this poor uninformed novice.
  13. SCEye
    SCEye F1 Rookie
    Aug 28, 2009
    2,950
    Norcal - Peninsula
    main battery switch is in the front trunk. in the passenger side. It's a dial you turn CW to turn off.
    don't know anything about CTEK sorry.
  14. 993man
    993man Formula Junior
    877
    New Zealand
    Graham
    So why do you need to do this anyway?
  15. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Jeff
    You can get new connectors for your battery tender from CTEK. I believe that the 430 has a connector for the Ferrari tender. Not sure if the matching connector is available from CTEK (who made the Ferrari tender). I also believe if you use the factory tender connector is gives you a warning icon that the tender is connected when you turn on the ignition.
    Here is a link to all of the battery connectors.
    Alan
    Accessories - CTEK Battery Chargers
  16. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    #17 GaryR, Sep 9, 2014
  17. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,105
    Calif
    Brett
    I installed my ctek to the terminals behind the drivers seat and ran the plug just up out of the cover box. This way I simply plug the charger into the small plug poking out behing my seat and then plug the charger in. works fine....
  18. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    That's where mine is also..
  19. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Terry's procedure is belt and braces (IMO you could safely start the car in a shorter number of steps). However, he is ensuring that the motorised throttle bodies and flaps have enough time to reset properly and that the engine re-learns its adaptive parameters.
  20. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    Thanks I'll bookmark this :)
  21. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    So how did it go?
  22. tazandjan
    39,073
    #23 tazandjan, Sep 9, 2014
  23. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    I'm just curious if his battery took a charge and he got the car running. Bugs me when someone posts a question, gets it answered, then disappears!
  24. dias7777
    dias7777 Karting
    Jul 31, 2014
    108
    sorry Guys. I didn't disappear! LOL I ordered a Ctek 5.0 MXS and waiting for it. Until then cant really do anything.. :(
