Light problem on my 328 GTB | FerrariChat
Discussion in '308/328' started by Rareusgold, Jan 17, 2006.
  1. Rareusgold
    Rareusgold Karting
    Sep 9, 2005
    162
    Florida
    Rich
    I need help? Do you know where I can get the lights to replace the ones in my trunk lid and the one in the doors? What are the part numbers? My passanger door light is out and so are both of the ones on my trunk lid?
    My trunk lights do not go on when I lift the trunk lid over the engine. Do I have to turn them on or are they automatic? Also the passanger door light is out. How do I get to the bulb after I unscrew the screws and pull it out (in the doors)?
    Thank you for your help.
  2. Steve Magnusson
    26,764
    If by "trunk lights" you mean the two lights in the engine bonnet over the license plate, I think those only come "on" with the parking lights or headlights (not when the engine bonnet is opened).
    However, if you mean some other lights on the underside of the engine bonnet, try turning on the parking or headlights at the same time (e.g., IIRC, on TRs, the extra lights for the engine bay only come "on" when bonnet is opened and the parking lights or headlights are "on").
  3. DBR328&330
    DBR328&330 Formula Junior
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    Hi Rich,
    If you mean the two lamps above the lic plate, they do commonly go out. First turn on your headlights. Did they go on? If not, tap them. Still not on? You can get them for about $35 each from Italian Car Parts. Often they will not work with the lid up but come on when closed.
    Dan
  4. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    On my 308, I was able to get my engine deck-lid license plate lights to work by unscrewing the two lamp covers and then cleaning all the contacts up there. There is some funky grounding think they've got going on as I recall. Give it a good cleaning and see if that helps.
    I replaced many of the bulbs in my car, including the ones in the driver/passenger side door (the ones in the armrests that "point down") with bulbs from Daniel Stern Lighting (http://www.danielsternlighting.com/). Pull the bulb and email him everything about it--size, markings, etc.--and he'll source a replacement (and these things aren't expensive).
    --Mike
  5. Rareusgold
    Rareusgold Karting
    Sep 9, 2005
    162
    Florida
    Rich
    Thank you for your help. The head lights have to be on for the trunk lid light to go on as well as the passanger door lights.
    Thank you,
    Rich
  6. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Hi Rich, when you say headlights, I think just the parking lights have to be on. Also, I when you say passenger door lights, which lights are you referring to? The ones in the armrest, or the ones on the "end" of the door itself in a little red lamp casing that you can only see when the door is open?
  7. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    One of my favorite things to do, resurrect old threads.
    My 83 308 license plate lights are not working. Bought the replacement fittings from ferrparts.com including new festoon lights. Put these in and turned on running lights and headlights and still no license plate lights. This with the decklid raised and lowered. Power comes from the right side of the decklid through a single yellow w/blackstripe wire.
    Any thoughts or ideas?
  8. Dockboy
    Dockboy Formula Junior
    594
    Maryland
    Good grounding from the fixtures to the bonnet is critical. Make sure the area around the 2 screw holes for each light is free of paint and making good contact with the fixture housing. Do the same on the fixture. Don't depend on just the screws to make the ground connection. There is a coating/paint on the housing.
    Also, have you verified there is 12v on the feed wire?
  9. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    12v confirmed. For the old lights ground is now very suspect. The new lights do not have a ground built in like the original. Additional wire required.
  10. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    Thoughts on using a thinwall rivnut to create the ground with an eye-ring?
