Buy
430 Lighting issue
Discussion in '360/430' started by tmvatlanta, Feb 7, 2022.
  1. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    264
    Covington GA
    Tam V.
    On my 06 F430 Spider, no light on with the main switch except the headlights. The “P” switch turn them on normally. Driving at night, I have no taillights unless I hit the “P” switch to have them on.
    I’m gonna check the fuse as first step. Any other advice or anyone experienced the same issue?
  3. CoreyNJ
    CoreyNJ Formula 3
    1,057
    New Jersey Shore
  4. mike32
    mike32 F1 Rookie
    May 13, 2016
    4,359
    Uk
    Front right and rear left sidelights on 1 fuse, other pair on 2 nd fuse. Sounds more like the contacts on the steering wheel stork as both yours are out. I take it the front sidelights come on ok
  5. tmvatlanta
    Mar 26, 2017
    264
    Covington GA
    Tam V.
    No lights on at all, with the main switch, except the headlights.
  6. mike32
    mike32 F1 Rookie
    May 13, 2016
    4,359
    Uk
    Fuse AF5 , AF 15+20 in the front boot to check.
    Relays AR 9+10+11 to check- use AR12 relay from horn to check others as all 20 amp.
    Qavion likes this.
  8. Qavion
    Qavion F1 Veteran
    7,496
    Ian Riddell
    Do your instrument lights work when you turn on your sidelights? Does the sidelight indicator work on your dash?
    This will tell you if your steering column switch is broken.
    Sidelight wiring diagrams here:
    https://www.dropbox.com/t/BvszFTWfYX9Mfh9A
    Do the lights in your push-button switches work and your licence plate lights?
  9. Qavion
    Qavion F1 Veteran
    7,496
    Ian Riddell
    Assuming your dash lights work, switch backlights work, rear numberplate lights work and that you haven't had multiple failures, I'd say you have a relay issue (AR9) or a wiring issue. Relay AR10 is ok because your Park lights work. Relay AR11 should only affect your switchlights and numberplate lights, not your sidelights.
    Fuses AF16 and AF20 should be ok because your Park Lights are working. It won't be fuse AF6 blown for the same reason. AF5 only affects switchlights and your rear number plate light, not sidelights.
    tmvatlanta likes this.
