Guys, My 360 manual is in the shop after breaking down at the ring. The flywheel bolts sheared destroying the crank sensors, spigot bearing, clutch etc. Luckily the casing and crank are fine. As part of the rebuild I'm planning on installing a lightweight flywheel, Toda or Aasco are the two I've found so far. Reading the forums most owners seem happy with their decision to install one. My only decision left is which weight to go for, Toda have three different weight options so I wondered if anybody could make a recommendation. I understand if you go too light the idle control motor can't react fast enough to 'catch' the rapidly falling rev drop. Any advice or comments on this?
