458 - Lines on brake rotors--is this normal or okay? | FerrariChat
458 Lines on brake rotors--is this normal or okay?
Discussion in '458 Italia/488/F8' started by Dragster, Feb 7, 2022.
  1. Dragster
    Dragster Formula Junior
    Jun 8, 2007
    501
    Charlotte, NC
    Hey everyone! I bought my 458 last summer as a CPO car, and I've probably put 1,000-1,500 miles or so on it since. Nothing at the track, just standard driving for fun and no hard or emergency braking or anything. The car is currently on the lift and when I went out to the garage tonight, I noticed that there are little lines in the brake rotors. I've noticed this on my cars with steel rotors before, but as this is my first car with carbon ceramics, I wanted to check and see if this is normal or okay with these rotors. The braking performance is totally fine, and there are only occasional squeaks from the brakes, which I've heard is normal. Thanks for the help!
  2. wthensler
    wthensler F1 Rookie
    3,509
    Gator Country, FL
    William
    Lance F likes this.
  3. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    That's nothing. Those,are in great shape. Here arw mine with about 15k km on them prior to going to Surface Transforms. Image Unavailable, Please Login
  4. Dragster
    Jun 8, 2007
    501
    Charlotte, NC
    Thanks for the follow up! I figured they were probably good, but wanted some more qualified opinions.
  5. FFan5
    FFan5 Formula Junior
    Jul 7, 2018
    550
    Carbon ceramics should be weighed to determine replacement time.
  6. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Depends on the type of disc.
  7. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    Those look brand new! :)
    Ray
  8. Fv81587
    Fv81587 Karting
    Aug 18, 2018
    125
    Novi, Mi
    Frank Valeri
    Sorry if this is a dumb question but what is Surface Transforms? Thanks, my 458 is also my first car with CCM brakes.
    Frank
  9. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,888
    France
    Surface Transform is another supplier of CCM discs (they are OEM for Koenigsegg for instance) which provides aftermarket solutions for Ferrari cars (for which the OEM is Brembo).
    The apparent consensus here (which I support) is that Surface Transform is more advanced than Brembo.
  10. And you can refurbish Surface Transform CCB rotors, another advantage. Though the turnaround time can be, to put it bluntly, long.
  11. wthensler
    wthensler F1 Rookie
    3,509
    Gator Country, FL
    William
    I should be receiving my Surface Transform rotors shortly, and will install them in my 458. They’re not cheap (around $13k), but my hope is the dreaded brake fade I experience on the track is greatly reduced or eliminated. I wouldn’t make this investment if I were just driving it on the street, but that’s not the case lately.
    Doesn’t take but a few episodes of decent brake fade to get one’s attention………..
  12. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Hehe, have to correct you here:)
    Surface Transforms, with an s on the end, does not manufacture CCM style ceramic rotors, they manufacture CCST style ceramic rotors. CCM which is Carbon Ceramic Matrix is the 20+ year old technology Brembo still tries to pass off as state of the art.
    The CCST technology is way more advanced and sophisticated than CCM technology.
    Rexcat458, mdrums, LVP488 and 3 others like this.
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
  14. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,086
    Todd
    there is a brake booster recall on this topic
  15. wthensler
    wthensler F1 Rookie
    3,509
    Gator Country, FL
    William
    Brake fade and failure are two separate things. I’m experiencing brake fade after repeated hard braking, related to overheating of the brakes and rotors. Let the brakes cool and the problem goes away ( temporarily).
    I’m under the impression brake failure is a catastrophic malfunction of the ability to slow or stop the car due to mechanical reasons, which I haven’t experienced.
    I will, however, follow the recall once it’s out assure the later never happens.
  16. todd cloud
    Jun 21, 2019
    1,086
    Todd
    partial loss of braking power is one of the failure modes
    brake booster intermittent seal issue
    could be your culprit
    Ferrari has been less than clear on cause/effect with this recall
    Frustrating
  17. wthensler
    wthensler F1 Rookie
    3,509
    Gator Country, FL
    William
    Well, I doubt it as it’s pretty repeatable with heat. But no, I can’t say for certain.
    Let’s install the ST rotors and see if that makes a difference.
  18. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    The 458 fade on track is very well known. It's not about the recall failures. They just have poor cooling. Once he's on better discs it will be gone, especially with upgraded RSC2 pads.
    Rexcat458 likes this.
