355 - Liquid leak from the front section | FerrariChat
355 Liquid leak from the front section
Discussion in '348/355' started by evo11, Dec 24, 2020.
  1. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
  2. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    Most likely either the heater valve (#5), heater core in enclosure or connections of those components as the fluid shown in picture looks like coolant.
  3. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Thanks a lot, have to fift the car up.
    Merry Christmas!
  4. Qavion
    Qavion F1 World Champ
    14,396
    Ian Riddell
    If it’s the heater valve, you’ll have to access it from the forward luggage compartment, by removing parts of the liner.
    You can’t tell what colour it is or the texture?
    Leaks I’ve had up front were due to a leaky brake/clutch reservoir and washer bottle, but assuming you have a left hand drive car, these would be on the left hand side. Other sources of leaks may be power steering and coolant pipework. I also had a loose clip on the coolant pipe which runs from front to rear and was accessed from under the car. A very simple fix once the underbody shield was removed.
  5. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,454
    Los Angeles
    You gotta stick your finger in the puddle and then smell it. Then you'll know.
  6. Bruce
    Bruce Karting
    Apr 27, 2004
    60
    I second the idea that it could be in the heater valve. Last year when I had the major done on my 355, my mechanic discovered some seepage in one of the brass junctions in this area. Fortunately, there were no significant leaks, just some seepage that discolored the metal. Apparently, if you get a serious leak the front luggage liners and interior carpets get soaked (and ruined), so its best to check it out sooner rather than later.
    If you remove the liners in the front compartment (easy and quick to do), you'll have ready access to all the relevant parts.
    Good luck.
  7. Bruce
    Bruce Karting
    Apr 27, 2004
    60
    Edit: I just checked the invoice and saw that on my car it was the pump (part #4 in Kokose7en's post) that was failing. On Ricambi's website, look for Part #70000900.
  8. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Maybe my eyes are going but I can't detect any tint to the liquid that would indicate engine coolant. When was the car last driven? Could it just be condensate from the A/C?
  9. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Hi guys, I noticed just after driving. I did some test drive 3 days ago. Its 2 degree outside so Im not using a/c or I don't know how stitch it off :(
    I think liquid is a little blue...
  10. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    Thinking about it now, it could also be your washer fluid leaking. Either the tank itself or part of the circuit. I use BMW coolant and washer fluid for the F355, so in my car both fluids are blue.
    308 GTB and Qavion like this.
  11. Qavion
    14,396
    Ian Riddell
    I didn't realise the early cars had the washer bottle in this location.
    @evo11 What year is your car, Evo?
    One of the reservoir mounting feet cracked on my car and left a hole in the base of the reservoir. I'm currently waiting for a second hand one (with motor) from Eurospares for my 5.2. The factory didn't have any new ones.
    I see Eurospares have a second hand reservoir container (only, no motor) for the 2.7 cars:
    https://www.eurospares.co.uk/parts/ferrari/355-27-motronic/bodywork-lighting/glass-washer-and-horns-41044/62536400
  12. A348W
    A348W Formula 3
    Jun 28, 2017
    1,849
    North Wiltshire, UK
    just man up and taste it! :) Probably won’t kill you, coolant and washer fluid are the most likely.
    KevZep and 308 GTB like this.
  13. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Hi Guys, carpets are dry.
    Liquid has dried up. Will let you know when I will lift the car.
    Thank you all for your help I really appreciate
  14. Qavion
    14,396
    Ian Riddell
    Are you saying the carpet was wet before or are you simply offering another clue?
  15. 308 GTB
    308 GTB F1 World Champ
    11,741
    New Jersey
    Barry Wolinsky
    That's what I've been doing for years to diagnose leaks and I'm still alive. :D
    A348W likes this.
