Liverty wants to change the starting Grid to 3-2-3 system | FerrariChat
Discussion in 'F1' started by 444sp, Oct 25, 2017.
  1. 444sp
    444sp Formula Junior
    Dec 18, 2016
    508
  2. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,508
    Honolulu, HI
    Three abreast heading into T1? Oh boy!
  3. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
    As long as Max is in the middle you can count on plenty of Turn 1 clean up...
  4. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    24,276
    Corpus Christi, Tx.
    Joe R Gonzales
    and Max in the middle....:D.....MAMA MIA!!!!
  5. Flavio_C
    Flavio_C Formula 3
    2,445
    Insubria
    Ha! It would be cool!
  6. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,843
    Atlanta
    John!
    Worth a go for a couple races to see how it goes. Interesting idea. Could by total mayhem though
    E60 M5 and DF1 like this.
  7. itschris
    itschris Formula 3
    Sep 15, 2011
    1,545
    Florida
    Chris
    I just about this is in the other thread. They can't make it through T1 now. It almost sounds as if crashing is an exciting part of F1. Its not for me. Like hockey, I don't want to see fights... I want great stick play. In F1, I want to see racing of the highest caliber. There's no joy for me at all to see carbon flying off the car of my favorite drivers or them being forced off or run into by some over ambitious upstart bombing the inside with no hope of holding the line. Actually that is the worst thing to me currently going on. When Seb or Lewis or any top driver's race ends in 30 seconds or less, it's a shame for the fans. I don't want to see turn 1 accidents anymore than I want to see grid penalties. What a stupid and insulting thing for fans to endure. Putting top drivers mid-pack or in the back because in the prior race some idiot rammed into them and broke their gearbox is a total **** punch to the fans. That's a disgrace.
  8. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,704
    ESP
    Bas
    Good luck at Monaco.
  9. Bas
    Mar 24, 2008
    42,704
    ESP
    Bas
    No surprise coming from the new F1 owners....land of destruction Derby and NASCAR.
    daytona355 likes this.
  10. 444sp
    Dec 18, 2016
    508
    Please you read the entire text before giving your opinion, I take the trouble to clarify that it would not apply in Monaco
  11. CSM0TION
    CSM0TION Formula Junior
    Oct 14, 2004
    969
    Long Island,New York
    Brandon
    F1 and WEC are two motorsports that would not in any way benefit from more crashing. For the most part the start is already the most exciting part of the day right behind Qually. Why are they wanting to mess around with that?
  12. hairy_scotsman
    hairy_scotsman Formula 3
    Apr 3, 2013
    1,134
    Austin, Tx.
    Tim
    Terrible idea. These guys can't handle 2-wide starts as it is.
  13. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    If they go 3-abreast, they better bring back the T-cars.
  14. daytona355
    daytona355 F1 World Champ
    12,655
    London
    Sid Korshak
    They'll need two or three t-cars with the low standard of anticipation and awareness demonstrated by the likes of Ericcson, Perez, Maxine, and a few others that tend to find pulling away at the start far too much to cope with, wherever they start on the grid
  15. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,369
    Cheshire
    Last time we saw a 3 abreast car run down to T1 was Singapore. That didn't go well...
  16. TheMayor
    106,023
    Vegas baby
    I like the idea on tracks of a certain width.
    If it's not wide enough (like Monaco) then it stays 2.
    It's about time F1 thought outside the box.
  17. crinoid
    crinoid F1 Veteran
    9,955
    LaCrinoid
    I like this concept.
  18. TifosiUSA
    TifosiUSA F1 Veteran
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Love it. Liberty brings lots of good ideas to the table
  19. P.Singhof
    P.Singhof F1 Rookie
    Apr 19, 2006
    4,819
    Stuttgart, Germany
    Peter Singhof
    It sounds very tight but if the three cars are standing next to each other it also has an advantage: they see each other
    I think with the current offset line-up the pole sitter does not see the second in the mirror (just a guess) when they start. So the one in front only can guess where the other is until he is next to him...Imagine the Singapore start with Max, Seb and Kimi next to each other would have most likely worked better because neither Seb nore Max actually saw Kimi from their point of view. Starting next to each other they would have most likely just took the corner in the order Kimi, Max and Seb and nothing would have happened...
  20. Lotaz
    Lotaz Formula 3
    Nov 18, 2016
    1,537
    Las Vegas
    Scott
    I would like to see them try it out for a few races and see how it goes. If it works better then great! If not go back to 2x2 starting.
  21. daytona355
    12,655
    London
    Sid Korshak
    It's only an advantage to those that can't make pole, so they jus aim for top three, not so sure it's fair to make people fight over pole, and then take away the advantage they've earned. It also means that typically, they will still arrive at turn one to go thru in order, except that fourth and fifth will be that much closer, effectively a concertina into the first corner where third might end up fifth by default..... rather than changing parts that actually work, they should be looking at allowing development and the use of parts as and when necessary without grid penalties which is destroying races
  22. P.Singhof
    P.Singhof F1 Rookie
    Apr 19, 2006
    4,819
    Stuttgart, Germany
    Peter Singhof
    Yes, the pole sitter might lose an advantage but it would be much better than reversed or random starting order as discussed here in the past. When the pole sitter is still on the best line for turn one he still has an advantage although this advantage is smaller than before. As someone said above: just give it a try, it should be easy to take back if it does not work....
    635CSI likes this.
  23. Igor Ound
    Igor Ound F1 Veteran
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    I feel its only purpose is to get more first corner shunts. I like it!
  24. 635CSI
    635CSI F1 Rookie
    Jun 26, 2013
    3,046
    London UK
    Graham
    Worth a try, though Ferrari* having a car that can really match a Merc, on a variety of tracks, is the only thing that will make it interesting for me.
    *Maybe Red Bull too, but that's not where my heart is.
  25. NEP
    NEP F1 Rookie
    Jul 19, 2010
    4,059
    On Earth
    Nigel
    OCTOBER 26, 2017
    Hulkenberg gives thumbs-up to three-car grid rows plan
    Nico Hulkenberg has given the thumbs up to plans to radically reform the F1 starting grid.
    We reported earlier this week that Liberty Media is contemplating lining up the cars in two and three-car grid rows in the future.
    "I heard about those rumours," Renault driver Nico Hulkenberg told Germany's Sport1.
    "For me it would be perfectly fine and I don't think it would cause more accidents."
    However, the German driver does think the alternating two and three-car row grids would be an issue at some circuits.
    "In Monaco it would not be possible to put three cars side by side on a row because of the width of the track," Hulkenberg said.
    "But the authorities will think about those issues after the season," he added.
