LM 002 thread | Page 6 | FerrariChat
LM 002 thread
Discussion in 'LamborghiniChat.com' started by Marcello, Dec 5, 2008.
  1. hashiriya
    hashiriya Formula Junior
    Feb 26, 2010
    352
  2. Rifledriver
    37,335
    #127 Rifledriver, Feb 7, 2017
    On any LM I have worked on, carb or FI the electric cooling fans take up the entire space between the radiator and grill. There is no space left for an A/C condenser.
    The fans move so much air it drowns out the radio. I rewired them so they only come on at 100c or above. They almost never run that way.
    Every cooled transmission I have ever worked on had an internal pump for pressurized oiling and used that to move oil to the cooler.
  3. Rifledriver
    37,335
    Did you make that radiator? Have never seen that design.
  4. Rifledriver
    37,335
    Our PS cooler is behind the left headlight and the trans and transfer coolers are together down below.
  5. S_AGATA
    S_AGATA Formula Junior
    Aug 24, 2016
    572
    Mill Valley CA
    Jon/Sean Sohaei
    #130 S_AGATA, Feb 7, 2017
  6. hashiriya
    Feb 26, 2010
    352
    The RHD radiator setup was done by Prodrive.
    It's weird because they had used the normal LHD steering box, which sits on the left hand side of the left frame rail.
    So now they had it on the left hand side of the right frame rail. So it was only possible with a weird radiator.
    BTW, I was happy with a fixed fan setup. Although it eats some HP, overheating was never ever an issue, once I tuned the carbs.
    Usually I had about 85c, summer traffic jams were landing me in 90c zone.
  7. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    That ia a copy of the original. My car along with the chassis 234 was converted to RHD by Prodrive UK. The weird shape is necessary due to the RHD steering mechanism.
  8. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    From the picture it looks like Your car only has twin puller fans. There is no pusher fans from the front of the radiator.
    Mine has twin pusher fans on the front and a mechanical puller fan directly driven by the engine shaft. My first pusher fans started at 85 deg Celsius and the second one at 90 degree Celsius.
  9. S_AGATA
    Aug 24, 2016
    572
    Mill Valley CA
    Jon/Sean Sohaei
    Correct. If it doesn't hold up I may try something else but worse case scenario I'll just put the original fan back on. I like the look of the radiator in the front but pusher fans are probably a good idea.
  10. Rifledriver
    37,335
    I thought yours was 234.
  11. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    My mistake. I meant 301. Mine is 234
  12. Mr Mezzanotte
    Mr Mezzanotte Formula Junior
    Aug 22, 2006
    653
    #137 Mr Mezzanotte, Feb 21, 2017
  13. hashiriya
    Feb 26, 2010
    352
    So here are the news.
    The part #27 dubbed as Spacer is a viscous coupling inside the transfer case.
    However, I'm 99% sure that in most cases it's already dead there, i.e. locking too soon and hard. So that's why you shouldn't run 4x4 mode unless sure that the viscous coupling properly slips and locks. I haven't found a certain test procedure yet.
    In 99% you should change the fluid in the viscous coupling before engagement on roads. So every LM002 should opt for a transfer case rebuilding these days, as 30 years passed, and all these years the silicon fluid spent inside a case full of hot transmission oil.
    As I've heard people do break the transfer cases, and that might be the reason.
  14. LNtoast
    LNtoast Karting
    Jul 11, 2013
    229
    Does anyone have details/VIN of the Green LM002 at Amelia this year?
    The paint reminded me of Malcom Forbes "money green" Countach (paint was also on several of his other cars).
  15. sultan722
    sultan722 Rookie
    Nov 26, 2016
    1
    Hey guys, I'm trying to replace my LM002 clutch, any Ideas.
    My clutch recently got burned, the car cannot be put in gear, even though i give it throttle it wouldn't move.
    What should I do, and where can I get a clutch?
  16. hashiriya
    Feb 26, 2010
    352
    Sounds strange!
    You mean, you can't put it in gear with the clutch pedal fully pressed? If so, would it start in gear? At firtst, it sounds like clutch cylinder problem more than actual clutch.
    You can get a clutch at your local Lamborghini dealer or eBay (some people have NOS clutches).
  17. hashiriya
    Feb 26, 2010
    352
    Recently I've bought few Countach 25th anniversary repair manuals and I can now be sure that my distributor was OK.
    The factory timing for L507 4V engine goes from 13 deg. advance at idle to 33 deg. advance at "over 5000" RPM. Which was exactly what I had on the down-draught LM002 with L510 4V engine (basically, identical, with only intake being different).
    Whether it's right or wrong, it's a matter of discussion. The car was significantly faster with the wrong timing I've set later on.
  18. S_AGATA
    Aug 24, 2016
    572
    Mill Valley CA
    Jon/Sean Sohaei
    +1 Did the same thing. Although there are other alterations, JLA12100 pulls much stronger than its stable mate (black LM earlier in thread).
  19. S_AGATA
    Aug 24, 2016
    572
    Mill Valley CA
    Jon/Sean Sohaei
    #144 S_AGATA, Apr 26, 2017
  20. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,099
    Rob
  21. Rifledriver
    37,335
    Just out of curiosity what did you paint the frame with? Was is a custom blend conventional automotive paint?
  22. S_AGATA
    Aug 24, 2016
    572
    Mill Valley CA
    Jon/Sean Sohaei
    We matched the original color and then had a blend made, correct. Its been a while, I have some stored away with its original interior etc.
  23. S_AGATA
    Aug 24, 2016
    572
    Mill Valley CA
    Jon/Sean Sohaei
    Hard to find accurate reviews of the LM. Even Jay Leno's was littered with false info - not saying he's not a great guy.
    Cool Period review
    [ame]http://www.youtube.com/watch?v=u2jth2ppbuY[/ame]
  24. Rifledriver
    37,335
    It was pretty good except for the Kevlar tire comment. I don't understand why everyone needs to attach some fable to the tires. They are Nylon just like every other heavy duty tire. The difference is DuPont owns the name Nylon so they called it by its scientific name Polyamid.
    The guy showing the car in Jay Lenos Garage didn't know squat about them.
  25. Rifledriver
    37,335
    I was wondering if you had found some industrial coating in the right color or if it was just paint. It looks good.
