LM-2 Graph Diagnosis & lean carb fix | FerrariChat
Discussion in 'Technical Q&A' started by BillyD, May 13, 2009.
  1. BillyD
    BillyD Formula 3
    1,840
    Pacific Northwest
    Bill
    #1 BillyD, May 13, 2009
    Below should be 2 graphs charting 1k to 6k rpm revs on my carbed 77 308GTB.
    As you can see the front bank stays at the best AFR of 12.5 in both low & high speed circuit, while the rear bank is as lean as 15 AFR in the low speed circuit & richens up to about 13.5 AFR when on main jets.
    So what you think could be causing the high AFR on the rear bank?
    Bill
  2. Ak Jim
    Ak Jim F1 Veteran
    9,834
    North Pole AK
    I would make sure of the results. Try swapping the leads to the O2 sensors. If you get the same results than try swapping the O2 sensors them selves. If you get the same results check the jets etc in each carb. As a last check could you swap the carb from front to back?
  3. Ak Jim
    Ak Jim F1 Veteran
    9,834
    North Pole AK
    Sorry, ment to say carbs, not carb!
  4. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,979
    Atlanta
    John!
    One intake cam could be slightly out of phase compared to the other causing more air to be drawn into the one bank causing the lean condition.
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    In addition to above, I'd would check to see:
    1. Jetting is the same for all 4 carbs (you'd be suprised)
    2. No small air leaks at the shaft bearings (common if original never rebuilt)
    3. The small filter screens on the carbs are clean
    4 Front to rear bank synchronization air flows close; Differences here can cause low rpm mixture differences front to rear
  6. Ferraripilot
    May 10, 2006
    17,979
    Atlanta
    John!
    +1. also. review ignition timing between the two banks and make sure they are the same
