LM002 RHD Rolling restoration.. will be updated regularly | Page 10 | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Apr 28, 2013.
  1. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    #226 BlueBiturbo, Oct 25, 2013
  2. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #227 BlueBiturbo, Oct 25, 2013
  3. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #228 BlueBiturbo, Oct 25, 2013
  4. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #229 BlueBiturbo, Oct 25, 2013
  5. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks for the info.
    Yes I keep hearing bad story about them. Good for the engine but bad for the headers in the long run.
  6. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    mostly I found them to just be a PIA, with no real improvement, in performance or preventing heat from the footwells ...the best change I made (noticeable heat shielding) were to make up some stainless steel sheets heat guards, which mounted under the car, to the floorboards (about 1/8-1/4" air gap)
  7. Ceramic coating the headers is more expensive, but maybe better. I had mine on the Countach coated inside and out. IIRC I paid about $400 to have it done.
  8. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    That is a good option. Thanks
  9. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
  10. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    Ceramic coatings yes-looks good reduces heat, preserves the header, wrap destroys the header,
  11. Lambrusco V12
    Lambrusco V12 Karting
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    I installed header wrap on a previous car, when I removed it I couldn't believe how much surface corrosion it had caused.
    You would think a hot header would immediately boil or eliminate moisture, I don't understand what caused the corrosion but I witnessed it myself
  12. nickinafrica
    nickinafrica Karting
    Oct 10, 2013
    164
    Spain
    Nick Petty
    I guess I must be a bit mad, I have just bought a 1990 LM002, and am working on getting it shipped back to Europe, I know it is going to require a bit of work, it has an oil leak that looks to be coming from one of the plug sleeves and is running onto the exhaust manifold, so I guess I will be getting the spanners out, most of the car looks pretty straight forward and over engineered, the only thing that really worries me is the motor, if that gives trouble, you will be in for a big bill
  13. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #238 BlueBiturbo, Oct 28, 2013
    Congratulations on Your new purchase !
    Please give us pics.
    I hope it is just a leaky gasket.
    Cheers,
    Taffy
  14. nickinafrica
    Oct 10, 2013
    164
    Spain
    Nick Petty
    I will post pictures as soon as I get it back into Europe, an oil leak from the top of the motor, should be either cam cover or the sparking plug sleeve, but until it is pressure washed, it is had to tell, on thing none standard is it has two spare wheels, one in the normal position and one on the inside of the gate, this I have never seen before, as soon as I get stuck into it, I am sure there will be plenty more post (cry's for help!!!!)
  15. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,163
    ESP
    Bas
    Awesome thread. Can't wait to hear the Ansa setup!
    I wouldn't...have heard a few horror stories. A friends' car also burnt down due to hot oil spitting on the wrap and causing it to go in flames.
    Use Zircotec coating instead!
  16. omd78
    omd78 F1 World Champ
    Dec 26, 2005
    13,255
    Breda, Netherlands
    Martin
    Please do!
    Gr. Martin
  17. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #242 BlueBiturbo, Nov 2, 2013
  18. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #243 BlueBiturbo, Nov 2, 2013
  19. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #244 BlueBiturbo, Nov 2, 2013
  20. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #245 BlueBiturbo, Nov 2, 2013
  21. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,099
    Rob
    What you going to use it, with respect to the 002?
    R
  22. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #247 BlueBiturbo, Nov 2, 2013
    Hi Rob,
    At first we thought the pipes could be used for the LM exhaust, but we have a classic E34 BMW M5 track car project, we may need titanium pipes for that car instead.
    I was shocked to know the list price of 1m aircraft certified titanium pipes and clamps. Unreal.
  23. Spyder-Man
    May 11, 2004
    2,099
    Rob
    Wow. Thats one expensive exhaust project. I'm enjoying this thread and can't wait to see the completed project.
    best
    Rob
  24. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Hi Rob,
    My friend got those pipes for almost free :D
    Thanks for Your interest in the LM project.
    Cheers,
    Taffy
  25. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #250 BlueBiturbo, Nov 3, 2013
