LM002 RHD Rolling restoration.. will be updated regularly | Page 18 | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Apr 28, 2013.
  1. Taurean Bull
    Taurean Bull Formula 3
    1,437
    On my way
    Chad
    Pretty tough to learn how to wire with your feet, since of course, your arms have been torn off.....
  2. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    #427 BlueBiturbo, Mar 27, 2014
    Hi Nick,
    Wiring is also not my forte. I built and raced 1/10th scale electric RC car since grade 5, that's it.
    Hopefully engine restart in 2 weeks, exactly one year after we started this project.
    Wish me luck.
    Cheers,
    Taffy
  3. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    LOL.
    That's a good one.
  4. Taurean Bull
    1,437
    On my way
    Chad
    Thanks, now my funny has reached it's zenith, so I'll be dull for a couple of months straight.
    The wiring really does look phenomenal, and frightening. I think I have all of 25 wires in the Jeep. ;)
  5. Lambrusco V12
    Lambrusco V12 Karting
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #430 Lambrusco V12, Mar 27, 2014
    I found that Jeep wiring is even worse and more unreliable than Lambo wiring (and that's saying something)
    Here's a parallel project being done at the same time as the LM , my Jeep J20 is being done in a similar color to the LM , they should look awesome prowling the roads together.
    The J20 pickup will also be rewired with aircraft circuit breakers, cables and wires.
  6. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    That J20 with 37in tires will be quite tall Tony, You don't need to make it taller.
    Most parking garages here are only 210cm tall.
  7. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    It won't fit in a parking garage anyway , it's 6 metres long , it's for projects and out of town trips mainly.
  8. Taurean Bull
    1,437
    On my way
    Chad
    #433 Taurean Bull, Mar 28, 2014
  9. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #434 BlueBiturbo, Apr 1, 2014
  10. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #436 BlueBiturbo, Apr 1, 2014
  11. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #437 BlueBiturbo, Apr 1, 2014
  12. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    sorry if i missed it,could you tell more about the aircraft wiring conversion?
  13. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #439 Lambrusco V12, Apr 2, 2014
    The main advantages of aircraft wiring are
    1. corrosion and vibration resistance, much more flexible also for routing large bundles of wire
    2. Quality - usually nickel plated copper or (sometimes silver plated copper) with very fine multiple strands
    3. High temperature resistance , good for 200 or 300 deg C before smoldering rather than catching fire
    4. I've never weighed it but I think there's a significant weight saving , I would guess 30 to 50%
    5. For this project it's FREE , I salvage Boeings and we can pull anything from 500 to 5,000kg of wiring out of an aircraft (turboprops to 747s) . Normally I retail it for $10kg to race car and off road vehicle builders and $250 of salvaged wire is enough for most projects, if you purchased new wire it could easily run to $2,000 or $3,000 for materials. We figured if we had to rewire the LM we have lots of material laying around the warehouse which is superior to chunky plastic coated automotive wiring.
    We also utilized salvaged Klixon and Texas Instruments circuit breakers in Taffy's LM , if you had to buy them new it would be about $6 to $7k
    Disadvantages
    It's not color coded so you have to code the wires yourself or do very good diagrams for future maintenance.
    We're also using mil spec / aviation connectors which requires a connector pin removal and installation tool.
    It's harder to work with than automotive wire and takes some practice but Indra (the tech) does this in his sleep during his day job.
    Summary
    These wires and cables are good for at least 50,000 hours of flying time and when I've pulled down aircraft for salvage the cables are still good after 25 or 30 years.
    It will last a lifetime in road vehicle.
    Finally it looks extremely professional and hard core on top of all the practical benefits, if you look at F1 cars most of them are using aviation or mil spec wiring.
  14. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks for the detailed answer Tony.
  15. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #441 Lambrusco V12, Apr 2, 2014
  16. marklintott
    marklintott Formula Junior
    585
    Taipei Taiwan / Somerset UK
    Mark Lintott
    #442 marklintott, Apr 2, 2014
    Forgive me if I'm missing something but how does that work fixing the starter shield to the exhaust studs - don't you get an uneven surface/leak with those tags sandwiched in there?
    My first post to what is an amazing job - probably a simple explanation too...?
    Cheers
    Mark
  17. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #443 Lambrusco V12, Apr 2, 2014
  18. marklintott
    585
    Mark Lintott
    Doh! of course - I knew I should have thought about it a bit!
    Mark
  19. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #445 Lambrusco V12, Apr 2, 2014
  20. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    I read in a motorsport brochure some time ago.
    Typical Race fuse 1amp-30amp is about $150
    ... while the same shape and size aviation grade (certified) is about $330
    What a difference certification makes :p
  21. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #447 BlueBiturbo, Apr 2, 2014
  22. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #448 BlueBiturbo, Apr 2, 2014
  23. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    I can't believe that in 3 weeks this project will be 1 year old.
    Funny I never thought I have the patience to wait this long.
  24. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,099
    Rob
    Worth it in the end Taffy.
    It's an amazing restore. The quality of the parts speak wonders.
    R
