LM002 RHD Rolling restoration.. will be updated regularly | Page 19 | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Apr 28, 2013.
  1. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks for the kind words and encouragement Rob.
    Hopefully I will be able to run the engine before her 1st Bday :)
  2. Lambrusco V12
    Lambrusco V12 Karting
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Should sound good through the new exhaust system
  3. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #454 BlueBiturbo, Apr 9, 2014
  4. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #455 Lambrusco V12, Apr 9, 2014
    I would prefer the injector electrical wires are kept clear of the fuel rails , a remote but possible chance of a fuel fire if there's a break down of the electrical cable insulation then putting current into the fuel rail.
  5. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #456 BlueBiturbo, Apr 9, 2014
    OK Thanks Tony,
    I will tell Indra tomorrow.
    So it will be on the middle of the V as per OEM setup.
  6. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Taffy , I can see what Indra wants to achieve , separating the two looms for troubleshooting in the future which is a good idea.
    I suggest running two tubes down either side of the mounting bolts but a few centimeters away from the fuel rail for easier removal of the connectors
  7. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
  8. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    could i/we get a little more info on the wiring,the wires are all the same colors ?,are they coded or printed as to where they go?,how would you trace a problem?,what am i missing?i work on automotive wiring every day and color coding is a great help
  9. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #460 Lambrusco V12, Apr 19, 2014
    I'll check with the tech , normally these used aircraft wires have specific wire codes printed on them at regular spacing (15 to 30 cm) when going into an aircraft so they're easy to trace.
    The tech has to draw up a new wiring diagram for the LM as part of the project with cross referencing to the wire numbering.
    Other methods are colored and or numbered ID rings over the wire.
    You can see some printing on the wires in the photo below , it's a mix of ID of the generic wire type and a specific code for that wire in the aircraft systems.
    In service the aircraft wiring itself rarely gives problems, the source is usually the connectors.
  10. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    thanks,great looking resto,
  11. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #462 Lambrusco V12, Apr 20, 2014
  12. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks dmaxx350.
    And Thank You Tony for explaining about the wiring
  13. LNtoast
    LNtoast Karting
    Jul 11, 2013
    229
    I have enjoyed follow your work!
    I did not think it would be worthwhile to post my color question in a new thread, so I hope you don't mind me asking it here:
    I have seen the Forrtune of Moscow LM002 pictures and wonder if that is a factory color. If so, what is it called?
  14. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #465 Lambrusco V12, Apr 24, 2014
  15. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks for the pics upload Tony.
    My flu and fever is killing me, stayed in bed all day
  16. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Hearing the V12 roar back to life on Saturday will cheer you up , looks like the boys will be on target.
  17. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Finally !
    Exactly ONE YEAR since 4/28/2013 This thread started
  18. MM355
    MM355 Formula 3
    Apr 7, 2008
    1,152
    GMT + 3
    nice progress
  19. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    I hope those Mario Spaghetti ECUs work
  20. norcal2
    norcal2 F1 Veteran
    I like your aircraft connector fittings! nice job!
  21. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,099
    Rob
    I look forward to seeing the video Taffy. Hope you taking one mate. Good luck on the first start up!
    Rob
  22. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    #474 Lambrusco V12, Apr 25, 2014
  23. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Engine start postponed till next Saturday.
    They found some wrong wiring two days ago and fixing it takes 3 days.
    I don't mind the slow pace as long as it is perfect
