Laust (home.earthlink.net/~laust/index.htm) who is on the VLG forum has installed Electromotive systems in both his Espada and his Jalpa. Try posting in the VLG forum, or try his email on his homepage.
Thanks. Haltech is roughly 40% cheaper down here, hence more tuners use that rather than Motec. I will do more research before I turn to any of the brand.
56 kg ! Ugh... heavier than my girlfriend About the same weight of Boeing 737 wheels& tires Image Unavailable, Please Login
I bought some JW Speakers LED headlights Headlights - Products - J.W. Speaker Corporation Image Unavailable, Please Login
Trial installation. Looks meaner, better and much more modern...oh.. and BRIGHTER ! [ame]http://www.youtube.com/watch?v=BZ1ivy90gZU[/ame] Image Unavailable, Please Login
That's it for this evening. Tomorrow will be more sanding the interior, rust proofing the floor, send the seats and interior panels to the leather shop.
Was away holiday for 9 days in Sydney, bought some VDO dials for the LM Image Unavailable, Please Login
My new fuse ... from MD95 / Boeing 717 Will also use main battery cable from Boeing. Much much better. Image Unavailable, Please Login Image Unavailable, Please Login
30 fuses ! Exactly what I need. I will repaint it in black, make new etching and reuse the fuse box and the aircraft push-style fuses. Will use new aircraft wiring which is better quality and fire proof. This fuse will be on the wall between the two rear seats. The car's interior has been done ... there was a badly rusted panel on the left front foot well (passenger side, this car is RHD). Panel was replaced, coated, and all the interior was sanded down and coated also. Pics will be uploaded later.
looking good! I found the VDO fairly dim lit, and swapped in LED each for brighter night time viewing, something to consider
Thanks JeremyJon, Yes all the instrument lights will be changed to LED. As well as LED blinkers, brake lights, interior dome lights, etc. The Headlamp is also JW speaker LED
Rewind a little bit to what have been done in the past 10 days while I was away : Found this corrosion on the left front passenger foot well, due to AC water leak Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Thank God there are no rust on other panels, just this one. We replace with 1.2mm steel, weld and rubber coat.
New interior deck .. bad BB pic Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Taking out all the wiring on the front of the car Image Unavailable, Please Login Image Unavailable, Please Login
