It may be a parts bin from an italian Tractor though :p
yes, total. We've done it and the time consuming part is carefully taking the interior apart to get to the twin rear fuel tank/seats and then removing them to get to all the rubber lines without tearing up any delicate leather interior. It is good to remove and seal the rear tanks while in there. It is less expensive for the later models with the fuel tank in the bed, however.
Hi Taffy, I think that is fitted to a Terex Bendini 4x4 rough terrain crane, I will take a close-up of mine & send it to a friend who works for a Terex dealer, see if he can supply
Haltech delay , we've been waiting for 3 weeks for the Haltech technician to check the installation , wiring etc before we power it up. We don't want to void the warranty. Endless excuses and now won't answer the phone.
Interior going back in and wiring progressing. The smell of all that leather is strong already Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Hi everyone, This is Taffy using Tony's laptop. SHE IS ALIVE ! Tue, July 15th 2014 ... after 15 months of work. Finally. The Haltech ECU solved the problem right away. Needs some final touch in about a week or so. We are VERY pleased to hear in running ... BIG grin on my face.
This is how it used to sound Lamborghini LM002 - before restoration - YouTube Couldn't run it for long (5 to 10 seconds) as the radiator is out to get access to the crank sensor and other ECU sensors
Before with the failing ECUs it would take 4 to 10 seconds to start , now about 1 second before it fires
It was worth the wait , the LM started effortlessly. We have to remachine the hall effect 'ears' on the crank pulley to make them smaller and then rebalance again , probably most of this week gone. I'm predicting a test drive in 3 to 4 weeks as the interior is still going in , final wiring to be done and now 12 thermocouples plugged into the ECU need to be installed and final tuning and setting of the ECU Taffy , is Haltech going to do the final set up on a dyno ?
