LM002 RHD Rolling restoration.. will be updated regularly | Page 41 | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Apr 28, 2013.
  1. Jasperlambo
    Jasperlambo Formula Junior
    Jan 16, 2012
    580
    The Netherlands
    Jasper
    someone LIKES welding :) !!!
    looks good :)
  2. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks Rob, Jasper.
    Yes the workshop likes welding a lot :)
  3. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1003 BlueBiturbo, Mar 2, 2015
  4. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1004 BlueBiturbo, Mar 2, 2015
  5. Rifledriver
    37,356
    What? You didn't like the 20 pound cast aluminum fan blade?
    I'd bet it takes 15 HP to spin it.
  6. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1006 BlueBiturbo, Mar 2, 2015
  7. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Hi Nick,
    Can You take a pic of that area please? Thanks.
  8. nickinafrica
    nickinafrica Karting
    Oct 10, 2013
    164
    Spain
    Nick Petty
    What do we need pictures of, let me know & I will do them now!!!
  9. nickinafrica
    Oct 10, 2013
    164
    Spain
    Nick Petty
    Sorry, Speedo reader, will sort it
  10. nickinafrica
    Oct 10, 2013
    164
    Spain
    Nick Petty
    #1010 nickinafrica, Mar 4, 2015
  11. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thank You Nick.
  12. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1012 BlueBiturbo, Mar 9, 2015
    Finally I remember to pick these up.
    1) Gearshift reverse lock.
    The old one is plastic and already worn.
    This one is aluminum alloy. I had to make a minimum of 10. I will keep 2 and sell 8 pieces. $30 each plus shipping if anybody wants one.
    2) Door hinges cap.
    I made 100 of these, same aluminium alloy stuff. I will keep 20. Needs 16 per car. $2.50 each plus shipping.
    Shipping should be very cheap since it is very light.
    I also made aluminium gearshift lever for myself from cast aluminium, but only made 2 and do not have any spare to sell. If anybody wants one I can check the price.
  13. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1013 BlueBiturbo, Mar 9, 2015
    Engine test run tonight.
    Turns out the problem of low left bank exhaust temp was the ignition wires are too old (for the whloe left bank).
    We made new wires, and test the car tonight.
    New problem emerges, the cyl 4,6 temp is a bit low, and surprisingly cyl 10 and 11 is dead. There is spark but I guess there is no fuel. Gotta check the injectors (all 12 are new) again tomorrow.
    We are already tired at 10:30 pm so hopefully tomorrow we will find the fault once and for all.
  14. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Cyl no 6 and 7 should be hottest temp since they are located far back close to the firewall.
  15. Lambrusco V12
    Lambrusco V12 Karting
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Those 12 EGTs are becoming very useful for engine diagnostics
  16. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Yes!
    Very very helpful.
    I am glad we install all 12 of those instead of only two (1 for each bank).
  17. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1017 BlueBiturbo, Mar 10, 2015
    Hmmmm...
    TWO Haltech coils malfunctioned.
    The first one happened about six months ago BEFORE we even start the car.
    The second one happened tonight after only about 300km of troubleshooting the LM.
    Haltech did not cover their coils under warranty.
    Priced about $120 each.
    Do You guys think I should complain?
  18. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Here is my ignition setting :
    Spark mode : Twin Distributor
    Spark edge : Falling
    Trailing spark edge : Falling
    Dwell mode : Constant change
    Trailing Dwell mode : Constant change
    Dwell time : 5.000 ms
    Dwell duty : 70%
    Ignition lock : Disabled
    Lock timing : 0.0
    Lock split timing : 15.0
  19. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Now it sounds like a Lambo V12 ... good work guys !
  20. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Brand new coils failing with less than 50 hours of operation , I'd be saying something
  21. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1021 BlueBiturbo, Mar 11, 2015
    Setting was incorrect, dwell time should be 2.5ms to 3.5ms max, not 5ms.
    BTW the second coil is free.
  22. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1022 BlueBiturbo, Mar 11, 2015
  23. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1023 BlueBiturbo, Mar 11, 2015
    We did throttle body adjustment on both cylinder banks, inspect and replace 4 of the brand new spark plugs and voila ! Everything works perfectly.
    We just need to adjust the fuel which is currently running a bit too rich.
    It has been 23 months, and to me it has been a wonderful journey with lots of head-scratching moment and patience.
    Thanks to Tony, Prof Indra and Agus for the hard work, suggestions and also a good teamwork in problem-solving during this project. Truly a world-class quality work by the team members. Special thanks to Tony for letting me use his office and his equipments, and access to aviation parts.
    I would also like to thank Chad, Emilio, Roy for the help in parts search. Thanks to Nick, Taz, Chad and everybody else in this board who gave many inputs and have the patience to read this long thread.
    For anyone else who is still thinking to own an LM ... just do it ! It is not an easy car to maintain let alone restore (this is my first rolling restoration project) but hey, the payoff is great. I don't see Lambo planning to make another 3100kg tank anytime soon. This is an oddball car made because they lost the bid for army contract with chassis leftovers. Typical Lambo in the 80s. It will not happen again with Audi 21st century management style.
    I am so very happy tonight.
    Cheers,
    Taffy
  24. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Taffy , no problem , it's been a pleasure
    I laughed out loud when I read this as if the project is over ... it's a 25 year old Lamborghini dude !
  25. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    It is over I hope hahahhaha...
    Just some very minor things.
