LM002 RHD Rolling restoration.. will be updated regularly | Page 45 | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Apr 28, 2013.
  1. Rifledriver
    37,288
  2. Rifledriver
    37,288
    Out of curiosity does anyone know where the "4WD" emblem some of the trucks have on the front fender came from?
    Ours has them but have no idea where to get them should I need replacements.
  3. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks Brian.
    I would guess the emblem comes for Chrysler parts bin... or other italian manufacturers such as Fiat, Lancia, etc.
    Can You post pic of the emblem again please?
  4. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1104 BlueBiturbo, May 2, 2015
  5. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1105 BlueBiturbo, May 2, 2015
  6. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1106 BlueBiturbo, May 2, 2015
  7. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1107 BlueBiturbo, May 2, 2015
    Screenshot.
    Torque improve a LOT.
    Engine also runs smoother, on the way home I thought the engine was dead/stalled and asked my mechanic "what happened" ? Turns out he was driving relaxed at 1500rpm but I felt no vibration from the engine bay :p
  8. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1108 BlueBiturbo, May 2, 2015
    5 Wheel HP difference and 6lb-ft torque with the fuel additive. We did not change any settng or timng advance between the two runs.
    I still don't understand why the wheel HP result s so low. Any difference due to the 34 inch tall tires ?
    LM now runs fine, smooth engine, pulls hard. It used to be running a bit rich but it was corrected today.
    BTW Dyno uses 3rd gear and pulls until 6750 Rpm but chart shows 5600 Rpm ??
    There was a UK-spec 2006 Subaru WRX 2.5 dyno tested before me running a mild 0.7 bar boost and got 204 whp which is about 268 engine HP (Dyno Dynamics use 24% loss for Mitsubishi EVO and Scooby WRX)... so I guess the dyno result for that car is about correct.
  9. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1109 BlueBiturbo, May 2, 2015
  10. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1110 BlueBiturbo, May 2, 2015
  11. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Next test should be rolling start acceleration race from 10 kmh to 100 kmh LM002 against an E34 BMW 530i 5-speed manual. Factory data says both cars acceleration time is identical.
    I the LM002 can accelerate as fast as the 530i then the dyno numbers are grossly understated.
  12. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1112 BlueBiturbo, May 2, 2015
    Aaaahhh... got this anwer from the internet :
    "Nelson performance did a study on this one and the conclusion was the bigger the tire or wheel, the smaller your hp numbers will be because of the extra rotating mass that you have."
    Well the LM wheels+tires also weigh about 50 kgs (110lb) each. That won't help. Also the center transfer case with reduction gear robs another HP.
  13. Lambrusco V12
    Lambrusco V12 Karting
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Dyno pulls are showing around 6,500rpm , look at the trace until the end not at the peak
  14. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Your LM002's target AFR of 14.3 seems high to me.
    I don't know about Lambo V12s but BMW V8s make best power at 11 to 12.5:1 AFR
  15. norcal2
    norcal2 F1 Veteran
    I think an Axle mounted awd dyno would give you better results if you had access to one, Ive used them on my Gallardo, and other cars, no wheel or tire loss...nice results though!
  16. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Any other LM owners dynoed their car yet?
  17. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Factory data says peak power is at 6800 Rpm not 5700 Rpm.
    Italian-sized circles ? :p
    Factory said fuel tank is 295 liters but it is actually 195 liters. Lambrusco typewriter ! :)
  18. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Running 2 gearboxes (transmission and transfer case) and massive heavy tires I would expect losses at around 30% to 40%
    Good that drivability has improved , the LM starts like a Toyota Camry now with the Haltech
  19. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Yes , something weird going on with Lambos power figures for the LM , same as their fuel tank capacities (290 liters is 200 liters)
  20. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Next time do a dyno run with the air filters disconnected , sucking straight into the throttle bodies
  21. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Tony,
    A good and efficient Scooby WRX with lightweight 17in wheels has 24% loss according to Dyno Dynamics manual. I'm not surprised if mine loses 50% :p
  22. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    I was about to do that today but forgot.
  23. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    There's still another 50 or 70 RWHP missing even with a 50% loss if the factory power numbers aren't lies.
    I think you're also getting weird results from the tires.
  24. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Tony,
    We need to test rolling start 10-100 kmh with Your 530i. It should be equal.
    Today I am happy with the corrected ECU setting. My shirt does not smell fuel anymore after driving the car. Really night and day difference. Car is not running rich anymore.
    I am VERY excited about the result of the R2F TXR. Higher torque from the low rpm. Peak torque difference is not that much but the low-mid rpm is a great bump where You need them the most on daily driving.
    12 Exhaust gas temp is 50 deg lower too.
  25. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    I think your going to see BMW tail lights in the distance :)
    Good stuff
    Yes it works , I'm pleased with the result considering there were no changes to the ignition or fuel settings which means there's even more power there if you want to bump up the ignition advance.
    What did Ovi (dyno operator) say when he saw the results ?
    Looking forward to the RON / MON lab results this week.
