LM002 RHD Rolling restoration.. will be updated regularly | Page 47 | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Apr 28, 2013.
  1. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    Hmmm...
    Maybe I should get some carb motor cams
  2. Rifledriver
    37,350
    Will require some mods to install. Would be far easier to regrind yours.
    You replaced the Microplex right?
    Have you spent any time trying to experiment with advance curves?
  3. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1153 BlueBiturbo, May 7, 2015
    What is a microplex?
  4. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1154 BlueBiturbo, May 7, 2015
    Brian,
    300/280 degree cam is borderline RACE cams. Also the 70 deg overlap is huge.
    It should give the LM a very rough idle and useless torque below 4000 rpm, not very good for a 7300lb tank.
    Are You sure it is 300/280 ?
    BMW E34 M5 Shrick upgrade 280/280 is already high, IIRC the standard M5 camshaft is 274/274
    Performance Camshafts: Increase The Power of Your Ride
    High performance camshafts start at 280 degrees of duration. These performance auto accessories have increased valve overlap but not too much so emissions and fuel economy are not severely affected. These are generally good camshafts for modified street cars and produce good power from 2,500 RPM up to 7,000 RPM but they do not have a smooth idle because of the increased valve overlap.
    A 290 degree camshaft requires more cylinder head work in terms of cylinder head porting and gas flowing as they work better when the engine's Volumetric Efficiency (VE) is improved. As you'd expect, these camshafts produce a fairly rough idle. These camshafts are generally good for rally cars and produce power from 3,000 RPM up to 7,500 RPM.
    A 300 degree camshaft requires even higher levels of VE, reaching the physical gas flowing limitations of a two valve cylinder head with a single camshaft. These camshafts are good for modified race cars and produce good power from 4,000 RPM up to 8,000 RPM. However, they have a very rough idle.
    A camshaft with a duration of more than 300 degrees is an out and out race camshaft with a power band in the 4,500 RPM to 9,000 RPM rev range. To make effective use of a 300 degree camshaft, you need to ensure that the engine has a very high VE. You also need to ensure that the engine can rev beyond the red line of most stock engines.
    http://www.crower.com/media/pdf/regrinds.pdf
    Look at right table #6 road racing cams
  5. Rifledriver
    37,350
    Don't really need a tutorial.
    Specs quoted from Lamborghini factory literature.
    The measure differently than what is considered standard.
  6. Rifledriver
    37,350
    Maybe a better understanding of the product is in order.
  7. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    They measured differently for sure :)
    eg : 295 liters is 195 liters
  8. Rifledriver
    37,350
    The carb truck does hold that much fuel. You just read the wrong source.
  9. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    #1159 vaholtorf, May 7, 2015
  10. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    Yes, the 1988 LM discussed in the previous post pulls to the rev-limit of 7500 rpm, although I have only done it a few times as I'm afraid of expensive mistakes! The dyno sheets show it pulling stronger and stronger all the way to about 6600 rpm when I released the throttle. I wish I would have pushed it a little harder, but all the noise and commotion on a dyno makes it scary to push too hard into the red zone on the tach!
  11. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    I disagree, and my previous two posts show otherwise.
  12. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    Moderator,
    Is there a way to move the last several postings into the LM section? That is where they belong!
  13. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks for the data Victor.
  14. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    There must be something wrong with our local dyno here, some adjustment is needed.
    It is impossible mine is losing 100 whp on a healthy engine.
    This coming saturday I will do a road acceleration test with my Gtech Pro
    G-TECH/Pro Homepage
  15. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Victor,
    I did my dyno pull using 3rd gear not 4th, the dyno operator was reluctant to use 4th gear. Is there any difference in the result ?
  16. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1166 BlueBiturbo, May 7, 2015
  17. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1167 BlueBiturbo, May 7, 2015
    68 liter per 100 km ?
    1.5 km per liter (about 3.6 mpg ?)
    I thought mine was bad, in fact it is the normal fuel consumption.
    So the Rally LM has a 600 liter fuel tank.
  18. Rifledriver
    37,350
    Only because they converted it to CIS fuel injection which begs the question why?
    CIS is a great way to throw away available horsepower. It has no useful performance application.
  19. Lambrusco V12
    Lambrusco V12 Karting
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    Pimp my Ride LM , I hate it.
    The only good feature is the quad exhausts
  20. porkchopious
    porkchopious Formula Junior
    Oct 11, 2009
    329
    Oakton, VA
    David
    Jeeeesus....
  21. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1172 BlueBiturbo, May 9, 2015
    Nice drive from 7am to another town, although being Saturday the road still has a bit of traffic near the toll gate.
    Total distance driven today is about 130 km round trip.
    Water temp is fine in the morning. 79C on long straight and 85C on bad traffic.
    Later that day when ambient temp rose (quite a hot and humid day today, it rained later in the late afternoon) the temp rose up to 98C on a stuck traffic and 89C on a slow road.
    After today's drive I am convinced that the Donaldson air filter is choking the engine. Next plan is to modify the air intake system.
  22. Lambrusco V12
    Apr 17, 2013
    248
    Jakarta, Indonesia
    Tony
    The chicken sacrifice at midnight helped :)
    Good to see the beast finally out on the road.
  23. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1174 BlueBiturbo, May 9, 2015
  24. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #1175 BlueBiturbo, May 9, 2015
