LM002 RHD Rolling restoration.. will be updated regularly | Page 57 | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Apr 28, 2013.
  1. nickinafrica
    nickinafrica Karting
    Oct 10, 2013
    164
    Spain
    Nick Petty
    Yes, Brian is correct, the LM EFI and the early Diablo have double chain off the crank to 2 jockey sprocket, and 2 single chains to the cams, all tensioned by sprocket wheels on arms tensioned by oil pressure, not sure what fails on the LM, the guides break, but that could be caused by slack chain.
  2. hashiriya
    hashiriya Formula Junior
    Feb 26, 2010
    352
    Ok, thanks for the info! That's bad that LM had minor information from the factory.
    Still people tend to take EFI LM as more reliable if compared to DD LM.
    Recently, we had seen a local car with 71000+ km mileage, "zero problems" as the owner said. But it was only 1.5 years he owned it. Arguably the highest mileage ever for LM002.
  3. Rifledriver
    37,316
    There was an update they should have all received replacing the upper hydraulic tensioners with manual tensioners.
  4. hashiriya
    Feb 26, 2010
    352
    How about the lower ones? Were they always hydraulic?
  5. Rifledriver
    37,316
    Yes. I assume there have been few failures of those and if they did it looks like the design would keep it from slipping on the sprockets and bending all the valves. Also, unlike the uppers you can't get to it to adjust it at regular services.
  6. hashiriya
    Feb 26, 2010
    352
    I've checked, all 3 tensioners were hydraulic from the factory and all 3 should be changed to manual tensioners.
    Yet, worse nightmares come true: the upper tensioners were designed to go on the tensioned side, which is why it causes problems.
  7. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
  8. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
  9. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Balboni is a very great and humble guy.
    He told me he was actively involved during the LM002 development
  10. Rifledriver
    37,316
    I finally figured out what these are. I thought they looked like BFG tread and I was correct. BFG used to make a LT345/55/17. Not been made in some time evidently. Oh well. It looks like right now a 305/55/17 gets us closest.
  11. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Too narrow I think.
    My 315 is only 255 wide
  12. Rifledriver
    37,316
    BFG lists the 305/55 at 10.1 wide but more importantly 32.6 tall
    They have 2 different 315/70 shown. One at 9.9 wide and one at 10.6 wide but both at 34.4 tall.
    If you already have rubbing problems 34.4 is going to be worse.
    Best would be to get Coker to make some 345/55 for us. Molds exist and Coker already has a relationship with BFG. That is what is in your old picture. It was marketed as a Sport Truck tire. The Hot Rodders liked them too. They had a good look on the rear of customized 30's Fords.
  13. GiZLabs
    GiZLabs Rookie
    Dec 18, 2019
    16
    Gena Za
    Hey, I saw you comment on the LM from Krasnoyarsk a while ago, do you know much about that car? It was recently offered for sale?
    1985QV likes this.
  14. GiZLabs
    GiZLabs Rookie
    Dec 18, 2019
    16
    Gena Za
    Looking for info on Clutch setup in an LM002
    my clutch recently failed, and when taking it apart discovered that the clutch disc had already been replaced by what looks to be a late 70’s Austin Healey clutch disc and not sure about the thrust plate. It’s 10.5” clutch disk and I’m wondering if anyone know what other clutch disks or thrust housings maybe compatible with the LM? I’m realising a lot of the parts here came from other car makers so wonder if anyone knows more about the clutch setup or compatible components
  15. GiZLabs
    GiZLabs Rookie
    Dec 18, 2019
    16
    Gena Za
    Any advice on A/c compressor for the LM002? Mine is missing and need suggestions on what to use that may fit or work well with least modifications
  16. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    The clutch is the same as the Ford Truck
    If You go back 25 pages or So I made a pic and description of what I bought
    JL350 likes this.
  17. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    I changed it totally to ND / Nippondenso.
    Not quite sure about the model, I can take a pic this weekend
    JL350 likes this.
  18. GiZLabs
    GiZLabs Rookie
    Dec 18, 2019
    16
    Gena Za
    Thank you, would appreciate it if you can email me directly, have another question if I may ask as I do my rebuild- [email protected]
  19. GiZLabs
    GiZLabs Rookie
    Dec 18, 2019
    16
    Gena Za
    Hi, I am trying to find out who was the LM002 body manufacturer in Spain, every article just says some company, but doesn’t say who. Anyone know who build the LM frame for Lamborghini?
  20. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Chassis by Urbar Ingenerios S.A.
    Body by Irizar
  21. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Chassis by Marchesi
    Body by Irizar
