location of engine number | FerrariChat
Discussion in 'Mondial' started by ozmondy, Oct 5, 2014.
  1. ozmondy
    ozmondy Formula Junior
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    I have the 3.0 QV 84 model.
    Can someone help me with location of engine number
    Peter
  2. Antwan
    Antwan Karting
    Nov 22, 2013
    188
    Manchester UK
    Engine block, front side just below exhaust ports, 8 inches above where the gear linkage connects. Engine codes to the side of the thermostat housing on the top of the block
  3. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #3 soucorp, Oct 5, 2014
    On the top of the block right where the water pump seals to it. You can see it from above no problem. The gearbox number is down on the bottom right corner near the motor mount if you want that number too.
    EXAMPLE provided by Steve Magnusson:
    On top of the engine block near cyl #1 -- this example shows engine serial number 278 of engine family F105E040:
