Lock Nut For Inner Tie Rod? | FerrariChat
Discussion in 'Boxers/TR/M' started by Dean B, Jan 27, 2014.
  1. Dean B
    Dean B Rookie
    May 8, 2009
    45
    Dallas, Texas, USA
    Dean B
    #1 Dean B, Jan 27, 2014
    I'm replacing Testarossa tie rod ends 103592 and would like to replace the lock nut for inner tie rod. The original lock nuts are not in perfect shape so it would be wise to replace them now. On the picture I have installed a new tie rod end but didn’t tighten anything yet. I have looked at the parts diagram and this nut is not shown. This is M12, 12.9 grade nut, but I do not know the thread pitch. Can anyone help me with this or maybe know where I can get this lock nut?
  2. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    I would try any European Carshop .... Audi, BMW, Mercedes, Volvo ...
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,531
    romano schwabel
    I meassured on mine here several times and have been very much surprised:
    the thread is M 13 x 1,25 with a 19 mm hexagonal
    an absolutely rare thread what until now I never have seen or used before. also have no tools for this. normaly there is M 12 x 1,75 or M 12 x 1,5 or M 12 x 1,25mm, M14 x 2 or M 14 x 1,5mm
    but a 13 mm thread is totally rare.
    could it be perhaps inch size???
    mercedes and BMW have M 14 thread. so I don´t know where to get 2 13 mm nuts from :( sorry
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #4 Crowndog, Jan 29, 2014
    Try 1/2 x 20 UNF. The 20 threads per inch relates to a pitch of 1.27 in metric. If it can be found in M13 try Maryland Metrics.
  5. Dean B
    Dean B Rookie
    May 8, 2009
    45
    Dallas, Texas, USA
    Dean B
    SAE versus Metric. SAE (Society of Automotive Engineers) uses a similar measurement system for nuts and bolts. The code follows the same layout of the metric nuts and bolts, but it uses Standard or American measurements. An M13x1.25 nut will be similar to a 1/2x20 nut. The two are not interchangeable but have threads that are close in size. SAE nuts close in size to a metric equivalent will seem to fit a metric bolt initially but will cross-thread the bolt.
  6. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Exactly.
    Many, perhaps most, suspension bits are imperial. As are all seat belts, and many transmission bearings.
    sent remotely
  7. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    you can eat breakfast off that suspension............... clean
