430 - Lock/Unlock Door Handle Not Working | FerrariChat
430 Lock/Unlock Door Handle Not Working
Discussion in '360/430' started by 1949live, Mar 17, 2020.
  1. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    I have a 2007 F430 F1. The driver's side inside Lock/Unlock little lever works fine and riggers the Lock/Unlock of the doors. The one on the passenger side does not work. I took off the inside door panel thinking it was the microswitch, but disconnecting the switch and shorting the two pins in the connector together does not cause the Lock/Unlock function to work. So clearly there is an open elsewhere. I have the shop manual but it does not include a detailed wiring diagram - does anyone have such?
    The next level in the connection chain appears to be the large connector that goes into the door from the car body. Anyone have any info on the pinout of this connector if I manage to get it open so i can test that path?
    Any other ideas how to troubleshoot this?
    Thanks much.
  2. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    @Flash 32: Wow - thanks! This should help. But the pics are pretty tough to read. Any chance you can e-mail me .pdf's of them? [email protected]. What document are these from - can one obtain them?
    Thanks very much again - much appreciated.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    Sorry about the quality ..I will cut and paste into a odd and post here in a little bit
    It is from a Scud wire diagram wsm I purchased .. I hope it is close to the 430 you have
    Give me few and I will post that and more in a PDF ..need time to select the area you may need ..
    Without any deep dive it may be you door lock ecu that may be bad.. but like I said I haven't really put to much thought or analysis into it
    Sent from my moto g(7) using Tapatalk
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    I think this is all you will need ... hope this helps
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I was having a hard time as well, would be nice to get my doors working from inside as well
  6. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    @flash32 - thanks much! Will let you know what I find.
    @mike32 - will also keep you updated. Anything that you already tried that you can share to help? Thanks.
    flash32 likes this.
  7. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    Dominik - your suggestion about the ECU is good and it would be simpler if I could simply test the switch connections at the door lock ECU. The part number for this ECU is 184391. Do you by chance have a pinout for this module? Thanks again.
  8. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    Sorry I should have looked through all the docs you sent - the data is there. Thanks again, and I will keep you updated on what I find.
    flash32 likes this.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    I don't recall..not in front of me .. but is two ecus if so ..swap and see what happens .. if there is one one .. sorry ..not in front of it
  10. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    Dominik - the docs you sent me has the pin out of the window control ECU, but not the lock/unlock ECU. Any chance you have that in your docs? Thanks again.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    #12 flash32, Mar 18, 2020
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    How did you make out
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
  14. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    Have checked out the microswitch and nearly all the wiring and can find no issue. So seems my next step is to replace the lock/unlock ECU which (amazingly) is fairly inexpensive - less than an hour of my mechanic's time - so worth the risk to replace. Once I get it I will let you know if that solves the problem.
    The lock/unlock ECU is pretty well hidden. It is under the water shield near the driver's left foot (steering on the left side of course) and tucked under the carpet. In the photo below it is "B".
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Great, any idea which wire gets the signal from the door lock lever ? They do a nice conversion to get the steering wheel on the correct side, you should have asked for it when you sent your order for the car in. !!
  16. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    Strange follow-up. My mechanic had an F430 in his shop, and I asked him to see if the lock/unlock on the passenger side worked properly. He indicated that it did the same as mine - only the driver side lock/unlock worked and the passenger side on did not. Does any other F430 owner have the same behavior? Mine is a 2007 spider. Thanks.
  17. JeroenF430
    JeroenF430 Rookie
    Jul 24, 2019
    1
    Netherlands
    Jeroen Vredevoogd
    I have exactly the same problem on my F430 spider. Is the problem solved by replacing the ECU and can you provide the partnumber?
  18. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    As noted above by myself and others, as far as we can tell this is a "feature" of the F430. At least the two cases noted above all seem to do the same thing. Don't think is is a coincidence. Hopefully anyone else who has an F430 and has both door lock handles working will chime in.
  19. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    I would also note that the passenger door unlock function still does work, i.e. lifting the interior door handle on the passenger side will unlock and open the passenger door. It just the function that would allow a passenger to unlock the driver's side door from the inside on the passenger door that does not appear to work. IMO an unimportant feature.
  20. gatago
    gatago Karting
    Jun 28, 2019
    119
    Marco
    I have a coupe and everything works as it should, except for I can't get the driver's side window to stay aligned for long. Interesting enough, I forgot to plug in the micro-switch last year and the car wouldn't lock until I took the door panel off and plugged it back in.
  21. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    But once you did that, could you lift just the LOCK tab on the passenger door and have both the doors unlock?
  22. gatago
    gatago Karting
    Jun 28, 2019
    119
    Marco
    yep
  23. 1949live
    1949live Karting
    Sep 18, 2014
    116
    Denver, Colorado
    David
    Strange. Curious to hear from others on their experience.
