Long, soft brake pedal. | FerrariChat
Discussion in '456/550/575' started by skl63, Dec 14, 2020.
  1. skl63
    skl63 Karting
    Dec 13, 2007
    228
    Melbourne, Australia
    Scott
    Hi,
    brakes feel terrible on our early 456GTA. Car has been sitting for a while. Long (very), soft pedal.
    Has had a couple of long drives over the weekend and it has not come good, so intend to bleed them??.
    Does this sound like a master cylinder issue and are they rebuildable?
    Thanks for your help,
    Scott
  2. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,642
    SF Bay Area, CA
    Ruben
    Seems like a good place to start is indeed a brake flush and go from there. Good luck!
  3. tazandjan
    39,164
    Make sure and bleed the master cylinder, too, if it has bleed valves.
  4. fatbillybob
    Aug 10, 2002
    28,989
    socal
    You can try a bleed you might get lucky. After long sits water absorbs in fluid. It make corrosion in moving parts rips seals in master then you feel as long pedal. So can be master. Sometimes you have marginal master and fouled at piston seal freezes piston then pedal effort pushes fluid past master seals. So actually if system is unmaintained and that fouled I would rebuild it all
