Looking for 1999 550 Secondary Air Pump | FerrariChat
Discussion in '456/550/575' started by SAFE4NOW, Jun 9, 2021.
  1. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,833
    Dallas Texas
    If you know you know
    Help, secondary air pump needed!!!
    Part # is 165903
    I have attached photos of the pump here, which I’ve been sending out to our various contacts.
    I’ve also looked into having it rebuilt, but have not been able to find anyone that will take on an electric motor this small.
    If you have any contacts/sources for one/rebuilder, it would be greatly appreciated, as it is the only item hanging the repairs up currently.
    Thank you all for your time and help!
    Steve
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Have you disassembled it yet?
    I'll bet the impeller is frozen in place due to plastic dust build up caused by the impeller rubbing the case. A through cleaning and possibly trimming the impeller will add some life time but it's a rare design with the input tube axial to the rotation instead of tangential as most other pumps are. It's also possible to add a small piece of very hard shim stock in the cover to act as a thrust bearing.
    As you know it's also used in some Maserati's and the 355 but I couldn't find any other use.
    SAFE4NOW likes this.
  3. Rifledriver
    37,106
    Recently I searched Amazon and I saw a few that looked easy to adapt. No direct replacements but until someone decides to make more a little fabrication is in our future. Who knows, maybe we will trip over a quality replacement. More than Ferrari offered us.
  4. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I spent many hours searching multiple sites looking for a suitable looking pump knowing that a whole new mount would have to be fabricated without success
    Whatever pump is chosen a new pump mount and hose routing will be necessary. I believe it's going to require a bit of thinking outside the box, all of these points are anathema to most Ferrari owners.
    Qavion likes this.
