Looking for a Mechanic in Westchester, NY | FerrariChat
Discussion in 'New York Tri-State' started by Adam Benalt, Jun 3, 2020.
  1. Adam Benalt
    Adam Benalt Rookie
    Mar 8, 2019
    9
    Adam B
    Anyone have a Ferrari mechanic they trust in or near Westchester, NY?
    And any tips on getting a PPI from another state/country?
  2. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,114
    I would only trust Miller Motorcars in Greenwich
    As a dealer they do everything from warranty repairs to ground up restorations
  3. Edc2104
    Edc2104 Karting
    99
    Greenwich CT
    Evan
    Tommy at P1 in Stamford CT.
    Miller is also good.
  4. gmoney56
    gmoney56 Karting
    Dec 14, 2009
    62
    Tommy at P1 .Honest guy and reasonably priced.
  5. ttforcefed
    ttforcefed F1 World Champ
    18,872
  6. Adam Benalt
    Adam Benalt Rookie
    Mar 8, 2019
    9
    Adam B
    After 3 votes for Tommy... called and spoke to him. He’s steering me away from the ‘88 3.2 Mondial I was asking him about, and says it’s easier to work on the T and it’s a better car to drive.
    Now I’m more confused because most of what I read says the T is more difficult because you need an ‘engine out’ for more service items.
  7. ttforcefed
    18,872
    what is a T?
  8. Adam Benalt
    Adam Benalt Rookie
    Mar 8, 2019
    9
    Adam B
    Mondial T ... last iteration of the Mondials. Came out in 89/90. They changes the engine config, added airbags and ABS... a more modern version.
  9. ttforcefed
    18,872
    I dont know anything about those but tommy knows his ****
  10. Dai Baracca
    Dai Baracca Formula Junior
    Mar 4, 2007
    573
    NY
    SB
    isn't that why you hire an expert for a PPI?? to give you honest advice about a car even if it might not be what you want to hear?
  11. Tiph206
    Tiph206 Rookie
    Aug 16, 2020
    13
    Tommy at P1
  12. Adam Benalt
    Adam Benalt Rookie
    Mar 8, 2019
    9
    Adam B
    100% And if he’d seen the car in person and could answer to why the Ferrari Dealer’s PPI was so negative to the non-oem parts... I would trust his review.
    But without seeing the actual car- he can only give me general guidelines. So, now I’m looking for some feedback relating to his notes. I’m not discounting his expertise at all!
    The part that the Dealer took biggest offense to was the fusebox mod- a scudderia rampante install Ed by a 3rd party. Which by all accounts is the right way to go, but dealer says it’s a fire waiting to happen.
    So I now need to figure out if that’s the Dealer’s OEM Bias, or an actual problem. Until I get more detail on that, I don’t want to walk away from a car that I want.
    If the car was truly improperly modded, and/or jury rigged unsafely... then I don’t want that headache.
    But I’m also not sure I want to move on to the later model T versions. They May be easier to work on, but I really fell in love with the 3.2.
  13. Dai Baracca
    Mar 4, 2007
    573
    NY
    SB
    my misunderstanding, I misread, I thought he actually gave the car a PPI, he merely spoke to you about it? Nothing beats an actual PPI
    When I was in the market for a 308 GTSi I had Norwood Italia in Texas do a full day PPI on the car. very extensive report. Served me well, well worth the money because I would have probably overbid.
    Adam Benalt likes this.
  14. rob
    rob F1 Rookie
    May 22, 2002
    4,139
    Vt
    A T may be easier to work on for him because it requires an engine out to do a belt service and he can pull the motor and work on it while it is removed. In all the research I have done on Mondials the T costs more to maintain than the 3.2.
    Someone telling you that a T is a better car to drive than a 3.2 is their opinion I would say you should drive both and decide for yourself. If you like driving the T better than the 3.2 and you can afford to spend a little more on maintenance you should go with the T either one is going to cost you some dough sooner or later so you should buy what you like.
    Dai Baracca and Adam Benalt like this.
  15. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    The T is more modern, has updated interior and same drive train as the 348. By all regards the T is the better car. Of course you have to remove the engine to service the T as it is Transverse, you cant do it from the wheel wells. But a car is more than the service effort. All that said there is a charm to older models like the 3.2 or the 328 despite lack luster performance. I personally LOVE Mondials, If I got one it would the the T in cabriolet though. I'd spend time in the Mondial forum and do some reading. These cars older models are very very easy to do a majority of the work on your self and diagnosing issues or CEL's is pretty straight forward, honestly not a lot different than muscle cars. Good luck!
    BTW not sure what non oem parts its referring to. A majority of consumable parts or parts that break/wear out are made by Bosch. TPS, Coils, Igniters IAC's, Fuel pumps the list goes on forever. In every one of those cases you can xref parts using the Bosch part number. The Bosch parts are the Bosch parts even if they do not have a Ferrari part number, in fact most parts ONLY have the Bosch part. Some things like FPR's are no longer made by Bosch so you have to get an equivalent like the standard Products FPR etc, but that;s true even if the dealer did the work, parts not available anywhere are parts not available anywhere, dealers do not have some secret stash of Bosch Part out of production, you can;t even order them from the factory.
  16. Adam Benalt
    Adam Benalt Rookie
    Mar 8, 2019
    9
    Adam B
    Thanks F -
    In this case, the biggest issue is the Scuderia Rampante Fuse Box. The dealer took issue with how it was installed. But overall he was just negative on the entire method of workmanship - an opinion which just isn't supported by any of the pictures or documentation the owner/seller has provided.
    And - yes - I know I'm biased by wanting this particular car. And - yes - having paid for the PPI, I should probably trust the PPI - even though it wasn't the answer I was hoping for.
    But - for some reason - I just can't walk away from this.
  17. Lenvo65
    Lenvo65 Formula Junior
    Apr 3, 2005
    293
    Bergen Cty NJ
    I have a 1986 3.2 Cabriolet, and had the Scuderia Rampante fuse box put in 8+ years ago, one of the best things i did on the car, as it cured many intermittent problems that were electric related. That box also take some of the bigger draw circuits out of the main box to a sub panel, which reduces risk of overheating the box. I expect its simply a dealer that is unfamiliar with anything but a bone OEM stock car. Also ask the dealer how they would plan to address the delamination of the circuit board that occurs on almost ever Mondial of this vintage, an part which is not available to buy anywhere. Search the Mondial forum and you will only find raves for Scuderia Rampante replacement parts.
    The other big difference you will find between 3.2s and T's is that with the T they added power steering, and they all had ABS and adjustable suspension (rear only I think) , which of those you will only find ABS, on the late year 3.2s.
    Auto Elite in Tenefly NJ ( just over the GWB), is outstanding and knows the Mondial line well - I seem to always see at least one if not more in his shop.
  18. Cort Moritz
    Cort Moritz Rookie
    Jul 7, 2020
    9
    NEW YORK
    Cort Moritz
  19. 26street
    26street Formula Junior
    Jan 30, 2021
    343
    Westchester New York
    Mark k
