Looking for coolant cap | FerrariChat
Discussion in '308/328' started by flyngti, Oct 12, 2009.
  1. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    In the parts sticky, a Stant 11229 and 11230 are listed as coolant caps that will work. I picked up a 11229 "equivalent" at Napa and it was a little too small. Can someone verify the fit of either the Stant 11229 or the 11230? This would be for a '78 308.
  2. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Yes they work. I have a 79, and it fit perfectly. You can pick one up at Pep Boys, if you have one in your area. If not, they probably have them at Autozone.
    Jim
  3. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    As a very-good mechanic has pointed out to me, one must NOT assume that just-because a cap will fit does not mean that it will 'work'. I'd test it before driving off with it - if it doesn't hold the correct pressure, I'd return it for a refund/exchange. I bought a brand-new cap from Rutlands, and within four months it wouldn't hold its correct 0.9 BAR pressure rating.
  4. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    My cap has been on for about three years, and it works great!
  5. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    11230 fits fine here. Seating depth is almost the same, the Fcar cap seat is just a tiny bit deeper by my measurements, I figure at most the Stant cap is down rating about 1-1.5 PSIG due to possible mount seating depth difference.
    I did have to work the cap on and off a few times until was real happy about being installed, it went one way, but wouldn't go on 180 degrees rotated at first.
    Doug
  6. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    What pressure do you need? I may have an extra Ferrari coolant cap in my little box of extras that you are welcome to. Its for a Mondial 3.2, but I think they are all the same. Just let me know.
  7. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
    For some reason the factory caps do not work on my 328! I have two (.9 and 1.1 bar) that always cause the coolant to overflow. I use one from Pep Boys that is problem free.
  8. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Several years ago, a Ferrari dealer confirmed to me that some of the coolant tanks were made with slightly too-deep necks. I had the "overflow all the time" problem (even after bleeding and with new caps) so I put a fender washer in the neck, which raised the seating surface just enough that the problem went away and has never come back in over five years!
  9. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    You just need to adjust the cap a little to make it fit easier. Take a pair of needle nose plyers and bend each tab on the cap . Do a little at a time and when it fits you'll know. Mine has been on for 5 years and no problems.
  10. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
  11. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Stant 1.1 bar..... $10. DONE.
  12. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    Thanks for your input everyone. I stopped off at a parts store on my way home and got the Stant. It's a little tight but seems to be ok.
