looking for donuts | FerrariChat
looking for donuts
Discussion in 'United Kingdom' started by F308 MAN, Mar 13, 2004.
Thread Status:
Not open for further replies.
  1. F308 MAN
    F308 MAN F1 Rookie
    Jan 19, 2004
    2,907
    Isle of Man
    Dave S
    the 308 has an aftermarket stainless exhaust and i require new donuts before i can refit the exhaust.....the big box has a stainless plate. 1" x 1.5" with the number 109062 stamped on - anybody any ideas of source ?.....the donuts are 50 mm ins dia. 65 mm o/s dia. 12 mm thick @ 50 dia and symmetrically reducing to 6mm thick at 65 dia.......the 50 mm dia sleeve type portion of protective mild steel (which is part of the three bolt flange detail) has corroded away, and i obviously do not wish to replace both st/st manifolds for the sake of this minor missing section......is it possible to buy fibre type donuts with these metal inserts factory fitted ???
    thanks for your time.
    david
  3. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    David
    By donut do you mean some sort of gasket or the rubber thingy's you use to hang the exhaust?
    if its the latter try your local exhaust n tyre place
  4. F308 MAN
    F308 MAN F1 Rookie
    Jan 19, 2004
    2,907
    Isle of Man
    Dave S
    the donut is (in my case) the fibre or glass fibre, conical sectional gasket which fits between mating flanges of the exhaust sections.......i have scoured all the local exhaust centres, but to no avail.......if i could source the aftermarket exhaust manufacturer, life would be easier - maybe i should post a photo.
    thanks, andrew
  5. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    Ahh now I know what it is, Dont F-U.K. do them, I have a few left over from an exhaust swap last year, do you know what size you need ?
  6. stevew
    stevew Formula 3
    Jun 9, 2002
    1,837
    uk
    Steve
    I got some from Ferrari UK last year when I fitted a TUBI to the 308.
    Steve
  8. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    #6 steve f, Dec 17, 2006
    I know that this is an old thread dave but i think you was telling lies back then as the doughnuts that you was referring to was edible as proof is in this up todate picture
