Looking for door Gasket | FerrariChat
Discussion in 'Maserati' started by Iceblue, Apr 2, 2013.
  1. Iceblue
    Iceblue Formula Junior
    Nov 5, 2012
    424
    Virginia Beach
    Olivier Perault
  2. Ruud Bax
    Ruud Bax Rookie
    Mar 18, 2007
    37
  3. george-mountain
    george-mountain Rookie
    Dec 14, 2008
    48
    Cologne - Germany
  4. Iceblue
    Nov 5, 2012
    424
    Virginia Beach
    Olivier Perault
    I think your car might be older than mine.
    Even the door latch is different, is your car GT 50's
    I have a 62GTI 3500
    I removed part of the rubber and there is a aluminum lip.
    I do like the aluminum trim however that your car has.
    After calling MIE again, they did find the piece of rubber needed.
    As per the manual, numbered 44 & 46 and 17 & 19
    Both are calling for rubber.
  5. Iceblue
    Nov 5, 2012
    424
    Virginia Beach
    Olivier Perault
  6. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,479
    Gentleman Racer
    I don't believe your seal to be correct type, in addition it would not have been fastened with the fasteners exposed as shown, they should be under the lip of the seal, and not be shown. But I may be incorrect here.
    I believe the correct type is a smaller width, and is similar to the seal on the front or "outside". In fact, it may be the same.
    .02 Lira.
    ~Trev
  7. Iceblue
    Nov 5, 2012
    424
    Virginia Beach
    Olivier Perault
  8. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    I would contact these guys. They are reproducing some good quality rubber parts and would not be surprised if they had what you need.
  9. thecarnut
    thecarnut F1 Rookie Rossa Subscribed
    Apr 22, 2006
    3,232
    Atlanta
    The Car Nut
    MIE gets many of the rubber seals from Cicognani. I agree, it is good quality.
    Ivan
  10. thecarnut
    Apr 22, 2006
    3,232
    Atlanta
    The Car Nut
  11. george-mountain
    Dec 14, 2008
    48
    Cologne - Germany
    3500 GT Coupè Touring carburators (1957-65) 3500 GTI injection (1961-65)
    15305100 WINDSCREEN WEATHERSTRIP SEAL 1ªSERIES € 240,00
    15305101 WINDSCREEN WEATHERSTRIP SEAL 2ªSERIES € 240,00
    15305110 REAR WINDOW WEATHERSTRIP SEAL 1ª AND 2ªSERIES € 220,00
    15315130 RH/LH HEAD VENT WINDOW RUBBER SEAL € 146,00
    15315132 RH/LH REAR VENT WINDOW RUBBER SEAL € 146,00
    15315133 RH/LH FRONT VENT WINDOW PROFILES KIT (1 SERIES) € 60,00
    15315162 RH/LH HIGHER DOOR OPENING RUBBER SEAL € 96,00
    15315165 RH/LH LOWER DOOR OPENING RUBBER SEAL € 48,00
    15315166 RH/LH BORDER DOOR-PANEL RUBBER € 76,00
    15315179 HEATING TUBE (3PCS) € 66,00
    15315181 DOWN BONNET DOWEL RUBBER € 16,00
    15315186 FRONT AND REAR BUMPER BRACKET COWLING € 72,00
    15315190 TRUNK RUBBER SEAL € 68,00
    15315239 RUBBER RING TANK FLOAT € 8,00
    15315240 TANK FILLER WITH DRAINAGE € 85,00
    15315250 RH/LH HEADLAMP RUBBER SEAL € 32,00
    15315251 RH/LH SMALL HEADLAMP COWLING ("GT" TYPE) € 26,00
    15315252 RH/LH SMALL HEADLAMP COWLING ("GTI" TYPE) € 56,00
    15315260 RH/LH REARLAMP RUBBER SEAL ("GT" TYPE) € 96,00
    15315280 RH/LH SIDE INDICATOR RUBBER SEAL € 22,00
    15315281 RH/LH SIDE INDICATOR GROMMET € 16,00
    15315308 DUST PROTECTION UNDER PEDAL CLUTCH AND BRAKE € 66,00
    15315309 DUST PROTECTION UNDER PEDAL ACCELERATOR € 39,00
    15315319 STEERING COLUMN RUBBER € 65,00
    15315330 RH/LH HANDLE DOOR SEAL € 19,00
    15315335 DOWEL DOOR STRIK RUBBER € 24,00
    15315417 WINDSCREEN WIPER PUMP BUTTON CAP € 18,00
    15315430 FRONT AND REAR TORSION BAR SUPPORT (6PCS) € 48,00
    15315720 SILENCER RUBBER SUPPORT (FOREACH) € 8,00
    15315740 HIGHER RUBBER STOP REAR SUSPENSION € 46,00
    15315741 HIGHER RUBBER STOP HEAD SUSPENSION € 42,00
    15315830 RH/LH CHANNEL SLIDE WINDOW € 26,00
    15315839 RH/LH GLASS SCRAPPER € 112,00
    15300000 TAP HEEL RUBBER CARPET SET FOR MOQUETTE € 120,00
    15300001 RUBBER CARPET N°1 € 60,00
    15300002 RUBBER CARPET N°2 € 65,00
    15300290 PEDAL COVER SET CLUTCH, BRAKE AND ACCELERATOR € 62,00
    15300003 PEDAL COVER BRAKE € 22,00
    15300004 PEDAL COVER CLUTCH € 22,00
    15300005 PEDAL COVER ACCELERATOR € 22,00
    A Lot of rubber parts for the 3500 GT as I mentioned before
